Best Way To Pick Up Jewels
DrRock
Quick report back. My jewel picker uppers arrived, and the little red one worked perfectly. Picked up the jewel I needed out of the little triangular white tray, lifted it over to the spot I needed it for, and just touched it with the tips of the forceps and it plinked straight into the hole. Perfect. No more jewels flying through the air into the black hole of the space-time continuum! ;)
  • 4 months later...
Marc has a good idea. I use mild soap and water, rinse well and air dry.
The larger green end I find useful for placing those pesky parts in the keyless and calendar works. Place, hold down with tweezer tips or peg and remove picker.
Another use!
The picker upper is brilliant for removing these annoying particles that stick to dials, even after using a puffer. Black dials in particular are particularly bad for showing up every dust little particle.
I think I may have to leave this forum, it's going to cost me money to stay here.  ;)
I use a spot of rodico in the end of a sample syringe needle, but this picker upper tool is "much more elegant and real professional looking"
Another tool I need, a few more dollars, ho hum..............
I know this is a bit of an old thread bump, but I wanted to keep all the information in one thread.
There is a supplier on fleabay selling those Marvy Jewel Pickers, but these ones are double ended ... so you get two size pickers for the price of one.
Free shipping to boot!!
http://www.ebay.com.au/itm/Marvy-Jewel-Picker-Tool-Double-Ended-FREE-SHIPPING-/371358065580?hash=item5676aa63ac
    • Never seen that but yes very practical Hector
    • Welcome, Simeon! I'm into Soviet watches too (not the political system, and yes, I am able to make the distinction, unlike some). They offer amazing value for money. I like your "Big Zero" profile image. It's a true classic and I have one of those myself. I noticed that the hands aren't the original. Not that it matters a lot but here's an interesting article about the Big Zero if you haven't already seen it.
    • I was thinking will the gasket stretch at all to match the desired size.  Did i also deduce that the original gasket is thinner (0 .5mm ) than the cousins gasket ( 0.8mm )  could that just be an effect of you measuring the case for the gasket size  H  ?
    • if we look at and understand why steel becomes magnetised and unmagnetised then its possible to work out why some devices are better than others. Simpy it is a parallel alignment of atoms , electrons within a material caused by external magnetic fields. Different magnetic fields cause different alignments and non alignment of atoms. Fields by AC currents are changing atom direction approx 50 times per second ( 50hz ). As a material is drawn away from a demagging device the field is becoming progressively weaker while also changing the material's atom direction having the effect of returning their random directions ( demagnetising ) . To improve on this demagetising effect, try changing the material's orientation as it is drawn away.  Fields caused by DC currents have the most permanent magnetising effect as the currect is flowing one way only. A good demagger would produce random magnet fields and disorientation of the material's atoms.
