6119 spec sheets
Welcome to the forum. I'm not aware of an acrylic that size you could use a crystal lift on. Can you post a photo of the watch along with the side profile.
By LittleWatchShop · Posted
When turning staffs, a JKA is invaluable and expensive. Fortunately, I inherited mine. There are crude alternatives to a lathe...like chucking something up in a Makita drill motor and using various grit sandpaper to make a pin. Won't turn a staff that way!! But, you can make a pin. -
Now that I think about it, I can probably just file down the pin carefully to the point where it fits. Is that too much of a hack?
You asked for an introduction. I have a Timex Marlin with a cracked crystal. (already said all this--sorry for the repeat in the introduction) I bought a Ling Hui universal crystal puller that was not universal. Can I find a larger puller or is there a different solution. RickG
