I have an Elgin pocket watch that I have had recently serviced because it would not run. Since I have received back from service the watch will only run when it is laying flat. If I carry the watch it stops. Any ideas of what the problem may be?
Elgin Serial#1140270
Grade 64; 7j; Size 8S; Model 1; Made ~1883
[email protected]
It could be many different things, but if you had this serviced professionally it should be up to the watchmaker to figure it out and make it right, that's for certain. But to echo Nucejoe, it could be a problem with a jewel, a balance pivot, hairspring touching somewhere; it could be that the escapement is poorly adjusted and the guard pin is rubbing the safety roller, or, it could be it was very poorly serviced and there is still gunk in there or way too much oil or no oil.
Does it run in both flat positions (dial facing up and dial facing down)?
Thank you for your replies. I have not tested it dial face down but I will. I will again return it to the repair technician. Thank you again.
  the "repair tech."   should brake into a cold sweat  when you walk in the door.    try to find proper watch repairman.   good luck.     vin
On question before you berate the watch tech. Did you ask for and pay for the watch to be “repaired”. Or did you as them to clean it/get it ticking?
"Get it ticking" is usually a sign to a professional to turn the job down. But sometimes you do a favor... but it'll tick in any position, might time like hell but it runs. If money exchanged hands it should run.
The request was made to get the watches running. I was told they would be cleaned, serviced, and properly adjusted. I left two watches to be serviced. The one I described earlier and an Illinois "Bunn Special" railroad pocket watch. I paid for and received both back after about 3 weeks and both stopped running on the hour drive back to my home. I returned the watches to the shop the next day and we are now in the "warranty" repair phase. I guess it is just trial and error now until the all of the issues have been identified and corrected. I didn't realize it how long it would take to identify and correct the problems. Hopefully at some point I will receive two fully repaired and correctly working pocket watches.
  • 3 months later...
Hello to All,
I hope everyone is doing well during this pandemic.
I previously posted back on February 4th. I had an Illinois "Bunn Special" railroad packet watch I was attempting to get repaired. I am still waiting for the pocket watch to be repaired. I am being told that it takes time to adjust it properly, parts are hard to find, the pandemic is causing delays in getting parts, etc. It has been almost 4 months since the watch was returned for "warranty" repair. Are these legitimate claims or am I being given a bunch of invalid excuses? How long should it take to get a watch repaired? My patience is running out. Any suggestions?
    • Of course, donor movement is needed, but the balance/hairspring assembly itself can be saved. OP, You just have to use tweezers and needle to straighten and two tweezers to untwist if needed to rectify the outer coil. What is seen in the middle may be is because the stud pressed to the spring, but we will need pictures after outer coil rectifying. The regulator and stud carrier are snapp-fitted on the antishock assembly. Lift and pry them together with some sharp tool and they will come off.
    • A good learning piece but think for the price of a new movement that's all it is. Probably just transfer the rotor if it's Citizen branded.
    • I'm no expert, but I'd guess this one is for the bin. Looks like it's been tinkered with by someone armed with a hammer and chisel. When the pallet, escape wheel and balance are all damaged it's beyond repair isn't it? Or a new movement if the watch itself is of value.
    • No need for special tools. Loosen stud screw and just push hairpsring stud out of the hole.  Regulator arm is spring circled around the setting housing, insert cutting edge of a safety blade under it,  opposit ( 180 degrees) to regu arm itself, and pry  half of the circle up, you then see how it all is made at put together. Remove the mobile stud carrier as well,  reinstal in proper order, first goes on the stud carrier, second put the regulator arm on top and press it home. Exactly as nev explained above. Trueing inner coils is done when balance complete is seperated from the cock.   The part thats bent over itself. 1-Unbend hairspring as much as you can when balance is seperated, just grab the hairspring stud in tweezers , grab hairpsring with another tweezers streighten with  strokes as you  move the second tweezers  away from the stud. 2-Move stud carrier and regulator arm as wide/ apart as they go , to provide max space which comes useful in next step. 3- Fit hairspring stud, into stud carrier hole. 4- Put balance and cock ( when attached together) back on mainplate.  5- You have enough space to grab hairspring in  tweezers to shape as you move your tweezers  away from stud.
