A Different Set Up
Marc
This is a new one on me.
This is the engine room from an AS1171 bumper auto that I'm working on.
Has anyone else seen or worked on this arrangement before?
Apart from the fact that it is all very dirty (this shot is pre-cleaner) and the mainspring is well and truly set, can anyone spot what is out of the ordinary with the set up?
Well spotted George.
Like I said, it's from an auto-wind movement, but rather than a slipping bridle on the mainspring to limit the build up of torque when the spring is at full wind, this uses a manual wind spring and barrel, but incorporates a slipping clutch (the domed star shaped washer) to couple the arbor to the ratchet wheel (which has a round hole rather that the normal square hole).
As I said this is a new set up to me and had me scratching my head when it came to dismantling it, and here's the question; how should this be lubricated?
After a fair bit of google I have been unable to locate any information on this arrangement, in fact all of the details I can find on the AS1171 show the more usual auto set up.
When I took it apart the whole thing was dripping in oil which can't be right. I have tried a touch of 8213 breaking grease on on the four points of the star and it is just too slippy, although this could be due to my use of a slightly stronger than spec mainspring, and I have tried it dry, but this just results in the balance galloping. This too could be down to the over strong spring so I have the correct spring on order, but if anyone knows what the correct lubrication is for this part it could save me a bit of faff when I install it.
Correct Mark, the ratchet wheel has a circular hole, the domed star washer has a hole with two flats which correspond to two flats on the arbor, the four points of the star washer friction couple to the top of the ratchet wheel. Any thoughts on lubrication?
Hi Marc,
I haven't seen this before either but then again, I haven't seen much I guess. :)  In any case, I can't figure out the function of the cross shaped part! I'd love to see a picture of the whole assembly put together.
@Geo: very interesting you bike, Geo! I wonder if a picture won't be much to ask? Thanks mate!
Cheers,
Bob
Edited by bobm12
Hi Bob,
here you go;
The screw on top is threaded into the top of the arbor and forces the points of the star down onto the ratchet wheel whilst engaging the hole in the star washer (which has flats) with the top of the arbor (also has flats). The ratchet wheel hole is round so there is no direct coupling between the wheel and the arbor. Torque is transferred from the ratchet wheel to the arbor through the friction contacts at the points of the star. When the spring is fully wound the auto wind system continues to turn the ratchet wheel but the friction couplings slip preventing any damage to the winding set up that would otherwise result as the mainspring is fixed to the barrel with no slipping bridle.
To dismantle this arrangement you have to immobilise the star washer with heavy tweezers so that you can undo the screw. If you don't hold the star washer the whole thing just spins.
Thank you Marc,
very interesting and now that I see it somehow in my mind it looks familiar from something I saw many, many years ago (kind of fuzzy in my mind now) It must have been some big chunk of machinery back then (I was a kid). I completely understand it after your perfect picture and explanation.
Very much appreciated,
Cheers,
Bob
I love the bubblebacks.
You may have seen this one
unfortunately it was when I thought it was OK to speed up the footage, the assembly is out of shot sometimes, but it was one of my earlier vids.
  • 5 years later...
    • Once you have the collet closer bits off, and the pulley off, there are two nuts on the spindle. These must be removed. There is a large nut in the back of the headstock with two holes, remove this with an appropriate wrench. The front large nut comes off too. The spindle now comes out- but wait- there's more! There is a spacer between the outer races of the bearings; the spindle will almost certainly come out "assembled" with both bearings and this spacer (it can actually come out front or back-ways with the large nuts off the headstock). You have to manage to press out the spindle from the rear bearing, get the spacer off, then remove the front bearing, now you can get to the key.   Imagining you get it all apart without causing any damage to the bearings, now the fun part starts. You must apply preload to the bearings, and this is a very tricky endeavor. Basically once you have the bearings back on, and are in the casting, you snug up the rear nut (one of the two) on the spindle, checking the play of the spindle with at least a 0.002mm reading indicator, until there is zero axial play, then just a little more, then snug up the second nut to lock things in place. Of course snugging up the second nut influences the preload, so you can go back and forth a few times to get it right. Too much preload and bearing life diminishes, too little, and you get poor performance, poor surface finishes, ball skidding, etc.   When I replaced the bearings in one of mine many years ago, I was surprised to find that the bearings were regular deep-groove bearings, but of a higher precision class than normal. I replaced with dimensionally identical angular contact bearings, class P4. In trying to set the preload, I just about lost my mind, so called Barden (the high precision arm of FAG bearing makers, and who made my new ones) and a nice engineer told me that the folks at Leinen were either crazy, or really good- he also said it's 100% A-OK to set up deep groove bearings with preload like this, but best is angular contact. In this bearing setup, the standard way to do it is to have a spacer between the outer races, and another between the inner races. Leinen has the former but not the latter, haha. His advice was to make an inner spacer. The trick is it has to be the exact same length as the outer spacer, within like a micron.  Then you just tighten everything up and the preload is set, because the bearings (the new ones) are ground in a way that they have proper preload in that situation. Easy. Sort of- if you have the means to make the other spacer!   Just to note- Schaublin does the preloading as Leinen did on these on their lathes using angular contact bearings. There is a procedure in the manual, where you tighten the nut until axial play is zero, then a certain number of degrees more. This works on their setup as the nut itself locks without a second nut, and they spent the time to figure it all out in a repeatable way.   I say all this not to scare you off from dismantling your headstock, just to give a heads-up what you're up against to get it back to where it was before.
    • Do, write a nice letter to Santa. I do all disassembly and assembly under the microscope. I consider it a necessity.
    • Yes Breguet overcoil, and A is OK, the damage is from B to the end. It should look lile this. The studd is fixed by the screw head into  the cut.
    • I opened up a 17 jeweled Swiss made movement only to find it has a pin pallet escapement. Not sure where the 17 jewels are but they ain’t on the pallet fork! Tips for lubrication?
    • Hi, This headstock is a little bit too modern for me to know my way round it. The pin that stops the collet spinning is sheared and needs replacing. Does anyone have advice on how to remove the spindle? I’m assuming that you remove the quick change assembly from shaft. Remove pulley. Unscrew front and back bearing plates on the headstock. Then press the spindle out applying pressure to the front (collet end). Has anyone done one of these? Any pictures or links to articles/literature gratefully appreciated. Thanks in advance. Warm Regards   Andy
