Hi, from an 'oldtwit'
oldtwit
Having been repairing clocks for some years, I was told by my wife that watches take up a lot less room, so I have graduated? downsized? to watches.
Have been doing it for a couple of years, my main interest is vintage mechanical but now trying kinetic.  Watches, parts etc sourced mainly from eBay and learning all the time from YouTube videos.
My main problems are hairsprings, and cat hairs from our two resident mogg (oops, will be in trouble now ) non-moggy cats.
Welcome to a great group of like minded old men (probably).
We have 2 cats and a dog. Luckily I use a roll top desk for my watches. I dust the Tambour door before I open it and make sure all my parts are in dust cover trays until I’m ready to install them. Also, I have to wash my hands before I start. It is very much like surgery. I may be a bit over compensating, but it works pretty well.
Dust trays are relatively cheap. You could use a sheet of tissue paper or similar to cover your work area while you are away.
I’ve had watches stop on me only to to open them up days later to pull a very fine hair out of the works.
Keep trying. You will find something that works for you and it doesn’t have to cost a mint.
    • The plate is OK, thanks. It seems the answer to my question is that this is a 'hack' & for me another reminder that in general, one won't be the first person to be tinkering with an old timepiece!. As you day, I've been fortunate to have gotten some good advice and, just as important, encouragement. I've been lucky then not to have the balance spring break as a result of my novice 'ministrations' - but I did remember to 'stroke' rather than bend per se. The clock is of sentimental value to the owner so I'm relieved to have now got it running to time with the support & encourage of forum members like yourself.
    • Thanks ww, its maybe not as much of a bodge trick that i thought it was.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  It would be nice if you told us a little about yourself.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  Can we help with what you are trying to  figure out?
    • In think you are effectively shortening the coil by shorting out damaged tracks. In my case as long as the continuity was good and the resistance not too greatly affected it should be ok .  One was on an era  movement,
