Anyone good at lathe work?
Alastair
I have a problem. Ive got this Slava Transistor watch--the one the Russians ripped off in the 60's of the American Bulova Accutron 214....
Its a fairly close match,-- visually they look identical, quite an achievement IMO...
My issue is this. Its third wheel has a rusted off pivot, fairly common on the Accutron version due to moisture or batt leaks and there's fair evidence of a leak in this one..
The Accutron 3rd wheel wont fit--2nd Moscow Watch Co (Slava, Seconda, Vostock etc) in their infinite wisdom made their staff smaller in diameter than the Americans, no idea why... My only solutions as trying to find a correct good third for this mega-oddball are near impossible, are-
1/ machine down Accutron third wheel pivots....
2/ Replace the jewels but dont know if plate holes are the same size and I dont have the equipment to deal with jewel replacement anyway.
So--Anyone good with the watchmakers lathe fancy having a look?
Edited by Alastair
I've repivoted Accutron wheels before, probably the best route for you. I've read that not only the pivots are different but the wheels themselves are slightly different, enough that they don't interchange even with resized pivots. These are apparently exceedingly rare- one source I saw says around 1000 made.
Sorry, I also do not have a watchmakers lathe, YET.  Just spitballing as to why they might be different sizes.  From my experience, companies and even countries use "standards" in manufacturing.  Standards reduce development, as well as, production time and the associated costs of bringing a product to market.  Not just because similar functions get similar solutions, directly reducing their inventory but it eliminates most of the decision making and reducing the associated tooling involved not to mention warehouse space.  If there isn't a compelling reason for doing something different, having a plan already in place certainly helps.
Shane
16 hours ago, Alastair said:
Well,--I had a lathe many years ago, Not a watchmakers one, but as you say it takes a lot of time and lots of bad language till you get it....
--Even then you never stop  learning...
     when i was a kid,  there was a pocket book,  "how to run a _ _ _ _ lathe". a compound lathe,  it helped me get into the aprentis ship.   i still have the book.    vin
18 minutes ago, watchweasol said:
Hi  I have 3 lathes and just about capable of using them not to any degree of being a machinist turn up the odd shaft and the like the fingers and hands getting stiff.
    good show,   age and wisdom,  keep collecting.  vin
Hi--The fact you mention that the wheels are not interchangeable ddoesnt really surprise me. Nothing much does seem to be exactly the same.
I dunno why they did that--Make a not exact clone, Ithought it would have been easier to make accurate copy....
Would you fancy repivoting this 3rd wheel I have? Beer tokens offered.....
    • I was wondering whether anyone could assist with some questions I have about my latest acquisition, which is a two train ‘Bravingtons Renown’ mantel clock - Pics attached I have done some reading about Bravingtons and believe they sourced movements from various suppliers, so I wondered whether anyone recognises this one. I have stripped and cleaned the movement and the clock is now running well, but there are a couple of dodgy brass springs that I would like to replace. I haven’t found anything suitable searching the internet so I wondered does anyone know of a supplier that might help. Last question is about the veneer on the case, it is generally in reasonable condition but there are a couple of patches on the top where the veneer has lifted. So far, I have tried to reactivate the existing adhesive by heating from below and above with a hair drier, then clamping for a day or two. It has improved slightly but the bulge is still visible. I’d be grateful for any advice if anyone has dealt with this sort of repair before.
    • Hi some pictures o& the movement and case would be appreciated so we can ascertain what the problem is you are having in fitting the movement.   Thank you.
    • Thank you very much,T. I'll try turning the arbour from the clock face end very carefully in case I haven't reassembled the suspension block correctly (I had to make up a suspension spring using remnants of a broken one as I haven't been able to find an exact replacement online).
    • Hi murks a picture of the front as well would help,   By the size of the plate it was stuck to I would suggest a coin cell,  2030,  2015 all depends on the height of the cell. And the space when the back is fitted.         3 volt.
    • We seem to have gone a bit quiet on this ?  Do we all agree to ask Mark for some input on this matter, or is no-one really bothered.
