A cheap source of spares......
I have a few Camy watches and couldn't resist this Camy 'Silver Cloud' on ebay despite its non running description (it was cheap, £11 inc p&p:P)
On arrival it was soon obvious that the movement was the old faithful FHF96 and balance spring was FUBAR'd:thumbsd:
I had a quick check around and found that I could get a new balance but couldn't justify paying the £30+ on this watch.
What I did find though that I could buy a 'good running' FHF96 equipped, re-cased and dialled 'Oris' from India for £13 inc p&p....
Well the 'Mumbai Special' arrived and I was suitably surprised with the obviously totally rebuilt movement in it (probably a new Indian built copy)
Not wanting to 'sully' the Camy with this movement, I settled for just swapping over the balance assemblies. I fitted the Camy with a nice new genuine alligator strap from Vietnam and the result is one nicely running vintage Camy and lots of FHF96 spares, total outlay, including the new strap, less than £35 including all carriage costs:D
Did that with a Seiko diver that I once bought but came with a movement in a very bad shape. Managed to find a cheap Seiko 5 with the same movement...
I wish I could do the same for really old watches as I just managed to break the arbor on a wheel of a watch I was working on and I can't even find parts. (and they'd be pricey if I did)
Did something similar with this Seiko 7548-700F (Stormin' Norman)...
Rebuilt the movement using a 7546 dress watch movement as the basis...(one of these days I'll probably fit the original movement bridge back, to get the jewel count, at five, correct again..)
And cleaned the dial as  best I could and replaced the hands and bezel insert with OEM Seiko SKX 007 parts...
I find resurrecting basket cases very satisfying:thumbsu:
    • I am pretty sure the correct practice to insert a tensioned crystal is to use a crystal press - although I always hate doing it as one slip and the crystal can skid across your dial, this happened to me on a Tissot, mangled all the hands and scratched the dial down to bare metal. I much prefer to remove the bezel and install the crystal into the bezel and then the bezel back onto the watch, not sure if this is an option for you?
    • Well, Geiger counter showed up today and the dial and/or hands were extremely radioactive, reading quickly spiked from a baseline of 10-20 cpm to 100 and was still rising when I removed it. Trashed the whole thing. Thankfully nothing else outside the components was registering - work surface, tools, the paper I had used to clean off some components....    And now I have a Geiger counter to use to  check practice watches BEFORE disassembly
    • Usually the coiled spring contacts the piezo sounder and the finger spring is the ground.
    • So I checked with my friendly local lab supplier and they can supply the following in 2.5 lt bottles: Tetrachloroethylene (B-Dip) - approx £65 Trichloroethylene (one-dip) - approx £43 n-Heptane 99% (Essence of Renata) - approx £35 Hexane - approx £45 I can't import or buy locally the 'real' products, hence the raw chemicals above. What do you think would be my best option? I'm edging towards Trichloroethylene - I know there are greater health risks, but given the very small quantities used for each treatment and 99.99% of the time it will be sealed in a jar, I think any risk is vanishingly small? This is mainly due to its assumed superior cleaning properties, or from the experience of this group, is the extra cleaning noticeable compared to its safer alternatives?
    • Unfortunately after much investigation, apparently the coil has been discontinued! Shall I get my service guy to try the solder or the conductive paint? 🎨 Final recommendation please🙏
