Fellow horologists, happy new year to you all and thanks for all the help so far and in the coming years.
Right here we go, I’m wondering wether or how do you set a pin pallet movement in beat?
as there are no pins for the pallet there is no visual reference of where the impulse jewel should sit when at rest.
So having read a few of Mr De Carle books where pin pallets are mentioned but he doesn’t mention anything about putting in beat.
de Carles'   old book mention bending and moveing the balance spring.   this is a way to correct the +  --   time.   i'll read that page again.    vin
Yes I saw that also, and the manipulation of the pin arms themselves for the correct lock etc.
I was wondering if there was a ref point to work from for the impulse jewel ( ok it doesn’t have a jewel but a nice piece of brass ) to be in line.
If the movement is powered down the impulse jewel sits off centre to the fork.
Let the balance wheel come to rest, the impulse pin/jewel is in beat, if a slight turn (in clock/anticlock direction ) of the balance wheel , lets the escape wheel/teeth to the verge of drop or lock.
At TDC ( top dead center) of balance wheel, ( balance pivot  & impulse pin & escape arbor fall on a streight line).
So mark the balance wheel ( at rest) and main plate so the two marks are in front of each other, turn balance wheel to the point you see the pin( pallet) about to drop or lock. The arch you have turned the balance wheel, is how much the roller or hairspring is to be adjusted.
Regards joe
Joe, many many thanks for the info, may I ask where you got it from ( book etc ) it has been a great help and I will let you all know how it goes Friday when I’m back at the bench indulging myself in my hobby for the day
No book, no school, that is a simple common sense approach to all mech timings, be it timing valves in automobile engines, escapement or else.
You would keep an eye on escape wheel,( for instance )observe when its about to do a drop you mark the angular position balance wheel is at, at that instance, that is when the fork is about to receive energy from the drop and deliver it ( the energy in the form of impulse) to the impulse pin/jewel, you want the delivery to happen at the instance the guard pin is in roller hollow. Think about the workings of escape mech,  the whole picture will come to you, you will master the approach,  in couple of tries.
Best wishes.
Hi  T  de Carles book chapter 6 there are several pages explaining the pin pallet operation and adjustment. Mine is the second edition and quite old. But as Joe explains its just a job of observing the lockings and making any adjustment as required. In beat is when the arm of the fork is centered between the index/banking pins at rest no powerand the pallet pins are just about to release and lock to achieve this its the same as theJewel lever done by adjusting the balance spring on the staff to achieve the center.
Hi  T  If you wish to delve deeper into pin pallet types and repair there is a book by Robert D Porter who seems to be the expert on pin pallets Amazon £35   ASIN B0006QQYE4  there is no ISBN number for it,  I have seen copies on ebay but all seem to be from America
Just looked at that book and it appears to be more for clocks. I’m working on a pin pallet pocket watch, although I might still get it and add it to my growing collection
   that book?    what is the title?     vin
Well all in line as best as I can tell, happily ticks away for approx 10 minutes then over banks, I had a post red this pocket watch a while ago, seems to be one of these problematic movements that is going to be on and off the bench for a while now
I check side shakes on fork and escape wheel arbar before touching pin pallets.
Adjusting pin pallets can consume a life. Good luck.
Hi T it might  be just a case of worn pins or escape wheel both difficult to acertain without part substitution.     If the pin does not lock and draw correctly they can be a P.I.A. and try your patience to enth degree.     all the best
    • You're asking a pretty broad question and you didn't specify the machine but yes it's simple especially if you have the right machine. The question has problems but I'll take it as it is. Is it really that simple yes especially if you have the right machine. So in the video below he's making a screw and yes it really is that simple but pay attention to the machine it is not simple at all probably wasn't cheap but it is small it will probably fit in your garage. Unfortunately wouldn't fit in my garage as it's far too cluttered up with things. In the video he talks about making a screw and pay attention to the machine. The machine has lots and lots and lots of cutters and lots of things to do lots of machining all-in-one machine conceivably one step after another all programmable. If you look at his channel lots of CNC's stuff and there are several other videos related to this machine. He goes to the factory where they talk about it and show all the other machines they make in Switzerland.  I did look up the specifications the machine I don't recall the price it's not going to cut wheels I think it has a maximum diameter around 11 mm basically it's really good for making small diameter watch parts. Then in one of the other videos he goes to a factory that used to make parts with waterpowered machinery been in business for 100 years and everything they now make is made with CNC machines including this one. What was interesting with the factory photo was that when they make some parts they can put them on a optical comparator comparator compares with whatever the reference is and the machine can be programmed to adjust its cutting to make sure everything is actually being made to specifications. Oh and then somewhere in all of this there was at least one picture of a balance staff can't have a CNC Swiss machine without making balance staffs.   It would be really nice if we had pictures of the machine. Then yes if you look at the page for wheel cutting you can enter parameters and it will generate a G code but he left out things? Notice he has a picture of a complete wheel but the G code isn't making a complete wheel it's only cutting the gear teeth I don't see whereas the program for crossing out the spokes? Typically when you see people cutting gears once the teeth are cut most the time the spokes are cut by hand. Occasionally someone will mill them out but typically not with the program which seems strange if you have CNC capability for instance one of my friends fill it used to design assembly line equipment or things to make things. So his hobby was to continue to make tools to make things like clocks. Very interesting and clever clocks but his true fund was making the machines to make the clocks. Then machine is not controlled by G code like we would typically find today as the stepping motor controller he has was made a long time ago and the individual controllers used a textbased program. So the company had a editor you could write a program to cause each the stepping motors to do something. So basically once you figure out how to cut a gear he would just change the parameters for different size gears so here's an example of a gear as you can see we have the teeth and the spokes. Then we have a picture the machine which sucks because it would've been so much nicer if I could've taken a picture when it was cutting a gears so we can see things better. Then yes there is a worm gear stepping motor indexing this is a mini lathe and the indexing is at the end of the lathe head hiding. The basic operation of this machine would be brass sheet not cut to a specific diameter size not even round mounted on the machine. Then it turns and a milling cutter will cut the diameter. Then the gear would be cut with a gear cutter. The same mill cutter for the diameter although conceivably change the size I don't know but basically the same milling for cutting the outer diameter would be used to cut the spokes. I really can't remember how he did the center hole but whatever it was was very precise.
