Timegrapher Repair
Behrooz
Thanks John. I just thought may be you guys knew of a 3rd party offering diagnostics and repair services on these. Brand is TYMC. Sending it them for a warranty repair may turn out to be more costly than nuying a new unit. So, I was looking for US repair.
at one time for the mechanical type timing machines cleaning machines etc. there were people that service them for the most part they've disappeared. I have some links below of people who service equipment you'll notice one of the companies in the UK has just now quit servicing but he might be able to give you a clue as to where to get your machine serviced.
Chinese timing machines are interesting there appears to be at least two separate manufacturers that's based on my observation of how the machine's work. One of the companies you have the initials of tymc does or did at least appeared to physically exist. The other company conveniently really really hard to track down I might've actually at one time found them and just wasn't quite sure because of the Chinese English translation. Basically they put a variety of clever names on their machines and users guides conveniently zero addresses or anything of where they're located. but the quality of the surface mount circuit board seems really nice for an invisible company.
Tymc does appear to possibly still physically exist maybe. They used to have a distributor in Germany I have the image off their website which no longer exists. Amusingly the German company was unhappy according to a discussion I found in a discussion group a long time ago going by memory that the machines got cloned because the company making the machines sold components to another company which resulted in warranty repair issues for the cloned machines. so while the German site is gone there is a Japanese material house that claims knowledge of their existence but this is a very old webpage. Then googling the information there I come up with the second link which is extremely unhelpful..
http://osakawatchparts.com/aboutus.html
http://www.stylewatch.com/CompAboutUs.asp?CID=1255
http://www.electronicinstrumentservice.com/index.html
http://www.delphelectronics.co.uk/index.html
http://www.algo-sales.co.uk/repairs/horologicalEquipmentRepair.php
Because they don't make it. Just like Apple or Lenovo it's outsourced to the likes of Foxconn, just a lot smaller.
    • I did try that last time Rich , i traced the image from the Bestfit book which is the actual size. But its more difficut to cut the shape from paper than it is to grind the steel to shape. This way is pretty easy and the final shaping is done when fitting the part. There are a couple of things i will do differently next time, clamping the 2 pieces together with a drill press will help to hold while scribing the shape in. This was a bit tricky having only one hole, if using the pins and cork the drill size needs to match the pin diameter so there is no movement at all from the template. This movement hasn't finished frying me yet, damaged thread in the plate crown wheel hole and two rubbed in cracked jewels, thats gonna be much more fun.
    • 👍 Whats not to follow OH ?  You're every inch a pro and a true gent, i always enjoy reading your answers even some of the clock stuff that i dont have a clue about.
    • Could you print the image either enlarged or reduced to the same size as the actual part and then glue it to the steel.
    • Next is to drill the screwhole this then provides an anchor point so the bridge doesnt slip around while scribing the shape. A cork lid, a pin and a piece of gaffer tape ( 😅 ) keeps it all in place. The hole is measured from the broken part using a hand measuring gauge. Mark the hole, punch it and drill it off to size. The awkward bit is working out where the jumper should be and the detent positions.  I remember watching a youtuber a while back do this with dividers, so i dug out my old school compasses and improvised a little. This bridge only has one hole and to find the detent positions you need two points of reference, so i just worked the second point from one of the corners, hopefully its near enough. Then scribe in the jumper using the two detent positions ( wind and time set ) that were marked and a big picture of the complete spring to look at that helps to give you a feel of where the jumper should be.
    • Right now I'm making do with a similar micrometer (the one below is $45 shipped but you can find better deals) and a $20 stand. You do have to be excruciatingly careful measuring jewels, since there's no table, but if you don't have the $500 to throw around, it's a nice option.
