Seiko balance removal
carlos123
Hi all,
I need to replace the balance spring of my Seiko divers watch but am unsure how it comes off. It looks to be clipped in but didn’t want to try and pop it out and cause damage, does anyone know how these come out?
Thanks in advance
Carl
You mean removing  balance complete, or the hairspring? Have you eve worked on a wathc mov't before?
Watch the video below but be aware that is a very delicate area, so it's pretty normal for a beginner to cause damage.
1 minute ago, carlos123 said:
Sorry it’s a bit early for me! It’s the hairspring I need to remove and replace. I have worked on movements before with some success but still a beginner
I see, I was confused by your pictures that have nothing to do with the hairspring.
As discusses already in the past, these hairspring are not removable from the balance staff. If you try, it will most likely break on removal or refitting.
So you will have to replace the balance complete.
I want to remove not from the plate rather than the balance staff just wasn’t sure how it pops off
Answered above:
Otherwise, what is exactly that you want to do, and why?
Answered above:
The hairspring looks like has had its day and needs replacing, either someone has had a play before or the “Seiko shake” has caused it to fail. It was gaining 500ish seconds a day. I wanted to see how the hairspring looks in its relaxed position to work out if it can be repaired or if I’ll have to buy a replacement.
You can take and post a good picture, normally minor hairspring defects can be corrected. For replacement, as mentioned already, the only option is the balance complete, which is quite expensive in relation to a complete mov't. They are also available from China for cheap, but I haven't ever tried.
I’ve seen the hairsprings and balance wheel for as cheap as £5 although not OEM. I just need to work out how to separate the hairspring.
The stud is removed from the plate by pushing the index into full fast, rotating the etachron key on the index to full open, and then just simply pushing on the stud out of the stud carrier clip. The Seiko collet is possible to remove. I have removed a few without consequence. Problem is, do you know how to vibrate an oscillator? A hairspring has to be tuned to each balance upon installation. It's best if you try to bend the original back in shape or swap in a pre-vibrated balance-hairspring combo. Replacing just the hairspring takes an unrealistic amount of time and resource for this low cost movement especially since vibrating a hairspring requires hours of work and expensive equipment.
Thanks for the info, I have no intention to remove the hairspring as a single component. So basically index into full fast, the turn the brass studs to release the spring?
What you want to do is called: Remove balance complete from stud arm
No. As written above: simply pushing on the stud out of the stud carrier clip
That is quite easy, but refitting is not so much. Refer to the attached, which has a section dedicated to this task.
7S26C_36C.pdf
7S26C_36C.pdf
Brilliant thanks [emoji4]
I find using an EtaChron removal tool the safest way to remove the stud, as it doesn't have any downward pressure, and removes the risk of slipping with whatever you are trying to pry the stud out with, also it takes away the risk of bending/snapping the stud carrier. All the pressure is sideways using the EtaChron tool. I made my own, which in essence looks like a 3 to 4 mm screwdriver head with a slot in it. As already mentioned, replacing the stud is a lot harder. Do this by having the balance fixed into the main plate for stability, with no other parts fitted
Image result for etachron removal tool"
af-185600-swiss-etachron-stud-removing-fork.jpg&key=ca252d983a527f5d2bddc5d2db66f8e2f54afd824d595ec14df9aa4f89ef4db5
Managed to obtain a tool that resembles your and worked perfectly.
I managed to manipulate the spring which was a bit of a mess and made it resemble a spring again although not perfect. On refitting the brass stud it shot off like a rocket detaching from the spring never to be seen again [emoji2955]
I’ve ordered a new assembly, hopefully I can master reconnecting it...
Thanks for everyone’s help
Cheers
Carl
I had opened a topic asking this but it didn't come to much. In the end, with the stud the right position, I push it inward with tweezers kept horizontal. Practice first with a scrap balance until you master the technique.
I actually bought two, just in case.... [emoji1696]
    • Mark keeps a close eye on his forum. I'm sure if you asked him he will reply, he might not do it right away but you will receive his answer.
    • I kind of think the same, the surface under the oil is the same as the surface around the oil. Can epilame both repel and attract , that doesn't quite make sense in simple terms, but is it more complicated than that. When cohesive forces within a liquid are stronger than the adhesive forces of a surface then surface tension is high causing the liquid to bead up. So  an applied epilame coating reduces the adhesive force of a surface inhibiting a fluid to wet the surface. So i guess no epilame cannot both repel and attract . If something is keeping the oil in place on top of an epilamed surface then there must be another reason for that.
    • I agree with @JohnR725. Oil on an epilamed surface is essentially the same as water on a waxed surface. The same physical properties are at work (surface tension vs. adhesion).
    • I think we all get a lot out of this group, and it has been pivotal in my development by the sharing of knowledge, experience and learning from more seasoned experts such as @JohnR725 and others (you know who you are!) as well as fellow novices. I think that having a backup communication plan in reserve so that if there is a future problem just makes good sense. I don't think anyone is trying to undermine the forum, but if something unthinkable happens, like the Ranfft website for example, then it would be good if those who are willing can still keep in contact. Speaking personally, and I know I risk a charge of heresy, it would be good if Mark could be a little more visible in this forum, and maybe give any insight from time to time on the future/progress of forum and instructional videos etc. even if its just to confirm the status quo. I appreciate he is a busy man with a full time job, but so are most of the rest of us and to post a few lines every now and then shouldn't be too much to ask to reassure the restless villagers. Best outcome for me would be a message saying something along the lines of: "Hi guys, all good, no planned changes... enjoy the forum, will message again next month!" Just my two cents.
    • A nice looking watch !! Did you try 9010, instead of the 9415, on the pallet jewels / escape wheel? And if you did, did you notice a difference?
