Winding stem
gary17
i'm not a real watch guy, but in much of any other fine work the answer would be "dremel tool" with either a grinding stone or a cut off wheel.  i think traditional jewelers used really fine toothed saws.  videos i've seen also use diagonal cutters then sharpening stones to dress what's left.  some ideas, anyway
Hi Gary   The tool shown by Dadistic is the correct tool, but make sure you clean up the end once cut should form a small cone to make screwing the crown on easier. once all correct and fitting snug and tested in the movement  a bit of loctite or s, glue and re fit the crown. Not too much and make sure you clean any surplus off before finally fitting
    • No idea Rich, but for your own sake please avoid inhaling the fumes.
    • I would try the vapour treatment very simple just a simmering pot of the stuff and jewels bluetacked ( not whitetacked this time, you still haven't said if I'm forgiven yet 🙂 ) to the underside of the lid. You're now gonna tell me that stearic acid can be highly explosive above 90° C 🤣
    • I guess it also depends on the precision and quality of the watch. He works on vintage watches mainly and surface treatments on 50 - 60 year old watches probably isn't going to make much difference. I read about nano coatings for car finishes. The article claims that nano coatings can reduced the coefficient of drag by 5%. Is that number significant? I don't know. Maybe if you were trying to break the land speed record. But applying that on a 50 year old clunker isn't going to make it go any faster, accelerate better or save on petrol. 🤣
    • 😅 yep certainly overdid it , i wasn't sure if i had enough heat so i went out and left it cooking. You can see the thick frosting, bit like my cherry buns.
    • 5 hours! You have slow cooked it! It must be really tender by now. @nickelsilver posted about his Greiner machine a while back. It had a heated chamber of stearic acid to epilame jewels and it only took 60 seconds. I've tried stearic acid dissolved in ethanol with a flake of shellac. I'm not really convinced by my test results. I conducted a side by side test by coating a mirror with a stripe of stearic acid and putting several drops of 9010 on the treated surface and untreated surface and observed it for several days. The 9010 spread out about the same for both the treated and untreated surfaces. I spoke with my mentor recently regarding epilame and lubricating pallet jewels. He has stopped doing both because he finds no significant improvements to the end result.
