Hey
I need to trim a winding stem as it's to long.
What is the best tool for doing a neat job.
Hacksaw? Pincers? Or something else.
It needs to be a good neat job.
Any suggestions?
Tanx
Gary
i'm not a real watch guy, but in much of any other fine work the answer would be "dremel tool" with either a grinding stone or a cut off wheel.  i think traditional jewelers used really fine toothed saws.  videos i've seen also use diagonal cutters then sharpening stones to dress what's left.  some ideas, anyway
Hi Gary   The tool shown by Dadistic is the correct tool, but make sure you clean up the end once cut should form a small cone to make screwing the crown on easier. once all correct and fitting snug and tested in the movement  a bit of loctite or s, glue and re fit the crown. Not too much and make sure you clean any surplus off before finally fitting
Any cutter would work. I use a Bahco side cutter . Cut it a little longer and use a pin vice to hold it and a diamond sanding plate to sand it down to the right length .
    • First of all, thank you for the pdf file of the book on how to replace a gem. So, if there is a problem with the ruby in the movement, should I buy a new or used movement and replace it? When I watch videos on YouTube of people fixing used watches, I feel like there should be a way to buy a gem. Is there no way to buy it?
    • I suppose @donutdan is not forced to earn his living by repairing watches.  I suppose he does it as a hobby and wants to gain experience, to get better in watchmaking and time is not the issue. Then @donutdan should rather try to repair the damage instead of swap parts from a maybe intact other movement. Swapping parts is not watchmaking. And often swapped parts are not the expected solution of all problems. All mentioned damages are repairable. Frank
    • Yeah I figured that one out when I googled and realized that my spindle is actually from Horia. It's smooth with no screwable cap.
