Low escape wheel
Ammar
Hello,
I am working on a Citizen 8200a movement that was running slow, I took it apart cleaned it and started putting it back together but the escape wheel decided to troll me and sit lower than the pallet fork and not even reach the bridge and the second wheel.
I checked the pivot,the jewel (which is flush with the face of the plate i thought I somehow have pushed it down but apparently I havent and it's not broken) and the bridge ian't bent and what is annying me is the watch was running.
By the way the main bridge or what ever it's called on this movement is a pain in the neck to put back in place I don't like it.
56 minutes ago, oldhippy said:
Did you remove the end stones if any? If so have you put them back in the right order. I would like to see some photos as I can't remember much about this cal movement, both side of the plates please.
There is no end stones on this movement (I have done this mistake before ^_^)
2 minutes ago, watchweasol said:
Hi Ammar  just a thought  if there are no jewel settings to have moved, Have you fitted the wheel upside down therefore putting the wheel on the wrong plane ?????. I have attached the tech sheet to help you
Hi I fitting the wheel the right way I am sure of that, I have a couple of spare wheels from another movement I'll see if the fit and have a try although the pivits on this wheel looks absolutely fine but I am out of ideas
49 minutes ago, watchweasol said:
Hi Ammar another thought and I have done this my self when rebuilding movements, Is the fork/pallet the right way up if not it would be the same , out of line.
I think you are right on this, or the pivot has been replaced at sometime and slipped in a tad further than was first fitted..
14 hours ago, Ammar said:
Hello,
Sure you got the other wheels in the right way up or in there jewels . Could be tricky to get all pivots in place. And the click is in place on the ratchet wheel.
3 hours ago, Ammar said:
uh um the second wheel pivot snapped on me yea... I hate this movement
Not the easiest to align all pivots on this . Has snapped pivots to. BTW which wheel do you mean? The wheel for the second hand don't have a pivot . Sweep second pinion it's called.  Think it's a spring that holds it down or up .
I meant the wheel that meshes with the escape wheel I was so frustrated when I made that comment didn't think of the terminology (not that I know what it's called any way).
I have another spare movement coming my way hopefully I can get it right this time  ^_^
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
