What's wrong with this Orient balance
Lc130
9 minutes ago, Lc130 said:
The bridge is flat as far as I can tell.  Am I wasting my time at this point?  Should I keep adding layers of foil?
Thank you
Charlie
The reason for these shims is usually after a new balance staff has been fitted which is a bit tight. The correct procedure is to hone the balance to the correct length. However some movements have them fitted as standard. If when you fit a shim the balance runs freely then you have identified the issue. The decision is to decide if the balance staff is too long or does the lower jewel need lowering a tiny bit. To adjust the height of the lower jewel you need a jeweling tool to move it in accurate small increments.
If the binding persists until such point that pivot get out of jewel hole, some data is generated, we may not at this stage spot the fault, but the generated data is valuable to narrow down possibilities, to be led to finding the fault.
I doubt anyone can see the bent in a staff or pivots unless under high magnification.
I am sure we will get it fixed, no one can gurantee before hand to spot the fault in certain number of go. We,ll just have to dig until we find it.
Best
Nothing to be embarrassed about. The lesson here is to inspect the balance when installed under strong light and high magnification. I’m glad that you check the end-shake. I actually thought the end shake looked slightly large.
    • I remembered that when Lititz Watch Technicum's YouTube channel existed, they had a video about polishing. As I recall, many experts thought that video was among the best on the subject of polishing. It's a real shame that their videos are no longer available and I've been in touch with them regularly to see if they can get these videos back. Unfortunately, it seems that these videos are gone forever. The last message I received from them on 21 January read: "I'm sorry, but not yet. In a nutshell: the school is scheduled to be shut down next year - a new school is bring opened in Dallas, Texas. Because of that all video access is blocked. If a decision is made to not close the school, then at some point the videos will likely be made available. We just do not know that yet. So, just check in again in a month or three; sorry I can't be more specific than that." Well, as I recall, there was a section in the video that was about how to preserve the edges of a watch case, that is, how to avoid rounding off the edges when using a mop wheel. I don't remember all the details but what I do remember is that it's about keeping a high speed on the mop wheel and keeping a light pressure on it. I didn't think of this when I was polishing the case back but the next time I'll try it and see what difference it makes.
    • Good idea, I  was thinking of something similar but using a drill press.  Apologies, all the other comments have just appeared.  I was replying to @HectorLooi , the chain pusher is a good idea too.
    • Now thats a real man's tool press 👍. I have one just like it in my back garden for when just CANT fix a watch . Its not something i have had to do yet, @Waggybut wouldn't any type of press be able to do this ? What about an adapted chain link  extractor work or a micrometer with some sleeve pushers made to slot over the ends. @Waggy Found something that could work Scott, comes with different size pins and pushers. Only bit that would need making is a round former to support the inside of the case, a piece of stout timber, bit of oak or mdf might do it. What i like about this one is the pin is pushed in, its in a sliding sleeve so it doesn't turn while its being driven. This has 4 pin sizes and 3 stumps as well so it will come in for other applications, the pins could be adapted to take other accessories from jewelling tools. I've just ordered one myself for some play time.
    • So I purchased this one based on my case number being listed. (Unless my case number is incorrect. The last digits are faint)
    • I have the same tool from AliExpress and get the same anxiety when when using it. But you have to admit it looks awesome on your tool shelf. Makes you look like a pro. 🤣 Looking at the photo of the Horotec tool, it looks equally flimsy. It probably comes from the same factory. I was thinking of using the pushers supplied with the tool and making a hand tool from a cranked jeweller's punch. I'll grind off the tip of the punch and drill a hole at the end to fit the pusher in. The cranked shank would be able to clear the watch case give a straight in-line axis to exert force to tap the pendant tube out. Should be robust enough to last several lifetimes. I wonder why nobody makes it. 🤔
