Seiko 7005 intermittent
Hello all, I have a Seiko automatic 17 jewel 7005-2000 watch that I would like to wear, however the watch stops from time-to-time and takes a finger tap to get it running again. If the issue is serious, perhaps due to age, and therefor expensive to repair then I'll have to consign it to the 'bits draw' but if there's a chance of an inexpensive repair then I would certainly have the work done. Any ideas?
Thanks in advance
Kind regards
Gordon
Hi from what you describe it sounds like the watch is a candidate for servicing . A good clean and lubricate. prices vary from repair station to watchmaker, or do it your self but that requires you to set up a repair station, If you wish to continue as a hobby then ok if not out source the repair.
Good advice from @watchweasol. Most likely a servicing issue rather than a breakage.
Imagine your watch as a little engine and where the pivots for the various 'engine' parts run in lubricated (jewel) holes. Over time that important lubrication deteriorates and the engine parts cannot spin freely and the watch does not run. When you tap the watch you give enough energy for the watch to run again and overcome the deficient lubrication but the effect is of course only temporary. What a watch service does is to dismantle the watch, thoroughly clean all the parts, re-lubricate the necessary parts and perhaps replace a worn item like the mainspring.
Much like a car service you could do this yourself but you'll need the tools and expertise to do it. Otherwise you have to take it to someone who can service it ... but as a skilled and time consuming job it's not a budget thing. So for most people how they proceed boils down to the value of the watch ... not only in cold monetary terms but also their connection to the watch. Unfortunately with perfectly lovely watches that are not of high value a lot of people decide the service cost is not worth it. A shame as there must be gazillions of watches languishing in drawers out there! :rolleyes:
That is a fault and is not said it can be resolved with cleaning and serving. So it may take considerable money and effort to fix something that is of very modest objective value.
Thank you very much for the quick responses, much appreciated.
Since I posted the original question 3 hours ago the watch is still running but has gained 35 minutes (running too fast) so I think I'll source a repairer and get a quote. Thanks again.
Hmmmm, now who to send it too...….
You can be quoted easily $150 just for service. Time is time and professionals can't care if it is spent on a $30 or $3,000 watch.
You can demagnetize by yourself and take a good picture of the hairspring and post it here.
150 $ or £ is clearly more than the value of the watch and I have no sentimental connection to it, and being a businessman who values his time I'll consign it to the bottom draw. Thanks again folks.
I need to correct myself as I've misread the OP, since it stops magnetization it not the problem.
    • Hi not found one either yet,  close relative is the 436 and 4361 according to ranff.db.   It gives quire a lot of detail but not as good as the old site.      RANFF.DB.
    • No problem to replace the setting with the staking set. Press the new setting from inside, use flat face punch with hole. The punch must be wider than the setting, the hole to be as not to press at the stone, but only on the bush. Press by hand until the setting gets flush with the plate surface, so the punch must rest on it.
    • Yes, the arbor usually makes about 3 to 3.5 turns. But usually spring takes 2/3 to 3/4 of the free space in barrel, not 1/2, so take it for the calcullations. This way the change in torque is smaller. I have a picture for You, this one is little older, but no mater
    • I overhauled a ladies Rolex and noticed erratic performance so I stripped in down again and did fault finding. This is what I saw. The lower jewel (the one in the plate) is cracked and the hole is too big. Before discovering this, I stripped down and re-cleaned the main-plate (and parts) by hand with a fine natural fiber brush. I somehow missed the fault the first time and cannot understand how it was still running. Perhaps re-cleaning it dislodged some pieces of the jewel widening the hole? I don't know. Now I need to replace the jewel but don't have a Seitz tool. The Rolex part is 2130-0913 and the top and bottom are the same. The part comes complete in brass setting with KIF elastor spring and cap jewel. Note: I have never replaced a jewel. I do have a good vintage stacking set that I've used quite a bit.  Can I replace using a stacking set? Any suggestions would be greatly appreciated.
