Hi Mark & fellow watch repairers,
First of all a big thank you to Mark for accepting me into his wonderful group!
Hello to everyone here, my name is Justin and I'm from Singapore. I'm a hobbyist who hopes to learn enough to become a professional watch repair man one day. For now I service & repair watches for family and friends in my spare time.
Looking forward to learning from and contributing to this group.
Cheers,
Justin
    • I would remove the wheels, check for damage and if not damaged, clean.
    • Thanks for the replies! Here's a photo of the front of the clock and a GIF animation of the movement (exposed by removing the black cap in the centre of the clock). You can see the behaviour of the gears. It's a fairly valuable clock from the 80s (Braun ABW 35). I'm not sure if replacing the movement would diminish the value, so I'd prefer to keep the original parts if it's easy to fix. But since the movement itself is pretty generic, I guess, maybe replacing it wouldn't make any difference with regard to the value of the clock? Or would it? I suppose the value is mostly in the design.
