Omega 1333 won't run.
I have serviced a 1333 omega .But it won't work even if the coil and circuit is okay . I have tested the coil. The circuit have pulse and i put it on a vibrograph it looks good. But won't run . Wheels runs smooth . i think i have tested everything but nothing seams to work. I thought a could have put some of the wheels upside down . But looked a the 1337 service here on the forum . And can't see anything i have done wrong . It's eating me up that i can't fix it.  Can it still be something with the circuit?
Did the watch work before you serviced it?
As you've tested everything what's the current consumption of the watch?
One thing you might try is isolating the gear train from the rotor. In other words put only the rotor in and providing you can see it see if that moves when you apply power. That's a rather interesting rotor if it was demagnetized or didn't have its proper magnetic properties that would be a reason it wouldn't run.
https://www.watchrepairtalk.com/topic/3913-omega-1337-quartz-movement-complete-service/
3 hours ago, watchweasol said:
Hi   Daft question I know but have you got power to the circuit.
I have put it in a vibrograf where i can see the pulses from the quartz crystal. But the rotor isn't moving . And if i put a multimeter over the 2 prongs on the circuit it gets a puls every second . The coil should be okay as i measured it to 3 ohms. DSC00479.thumb.JPG.e832ddd1ba9ad6a4dae793a055e74322.JPGDSC00480.thumb.JPG.ca5bdb18507edd87164705f37c985c89.JPG
The minute and second hand moved before i serviced it but now it's not moving. I can get it to move a little bit but stops after a few seconds. Good tip with removing all wheels except the rotor.  I will do that . Should be easy just to remove the wheel next to the rotor . Could very well be the magnetic on the rotor.
Where are you measuring the pulses to the coil?
It may simply be the case that the contact between the coil and the PCB is not too good (open circuit, or high resistance, due to dirt/oil/corrosion on the PCB pads. If you can measure (carefully) on the coil itslmf, or better yet, if you have a small compass or hall effect sensor to pick up the magnetic pulses then you will know if the coil actually works.
Is the rotor tuning freely? Is there any magnetic debris stuck to the rotor?
As all the component parts seem to be in order on their own but not in the whole something untoward is happening, As Andy remarked the coil /circuit joints, or  a stuck up rotor.  Can you see if the rotor turns as it receives each pulse, If it is then there is no connection between the rotor and the train. Might be damaged wheel teeth or a damaged rotor gear.
Tinkered with it today. Did as JohnR725 said and run only the rotor . Worked . And when i put the wheels back it started to run. No idea why or how . But as is now it's working . I am going to let it run . Need to adjust the hour hand a little but at least it's working.  YAAAAAAAAA. DSC00483.thumb.JPG.706c39c52ad00f2cfab074bc97a308ea.JPG
  • 8 months later...
Found this again the other day. The hour hand is standing still . The minute is moving since i serviced it.  Why is that? The hour hand is turned by a magnet instead of a cannon pinion. There most be something with the hour magnet. Finding parts for this movement is almost impossible.
Edited by rogart63
Since I can only see one coil, in the examples I found online, then I presume from your description that there is a small magnet on the minute wheel that causes the hour hand to "click" at the top of the hour.
This seems a strange arrangement, given that I can see a bunch of gears there too, Why use a magnet  when you could simply gear the hour wheel from the minute wheel. Can you provide more pictures of the way this works?
Could the issue be due to drag caused by dirt or corrosion, rather than a problem with the magnet.
Time for some close magnification work to inspect gears and pinions I think.
Edited by AndyHull
    • Thanks, ManSkirtBrew.  I started looking for a setup like yours and ran across this.  It was about half the price of the JKA Feintaster (depending on what auction you were in), and it's a Bergeon.  I bought it because I thought the price was fair (eBay - Buy it now), and I'm a sucker for vintage tools. It also has a table, so it should be easy to use for measuring jewels. I wonder if the the contact points can be changed out. Bergeon seems to manufacture new tables and accessories for the contemporary dial version. What do you guys think of it? I'm sorry this post seems to have taken a detour. I'm new here so let me know if I should start a new topic.
    • This is a flying cutter, usual one. The cutter itself is shown in the pictures in the first message, it is made of broken tungsten carbide drill bit. I asure that all the angles of the cutter are as they should be. I have video - little older one - that I made when onse making the same kind of winding pinion for a Poljot 2200, which is even smaller than this one. It is not easy to see in the video, but the tool rest moves about 1mm towards the object in Y direction and then returns back untill cutter is rotating. Then the spindle is rotated one tooth ahead and everything repeated untill all teeth are cut.
    • After a bit further research could it possibly be an AS 970?
    • Latest project was a non-running ebay purchase with an FHF70 movement. I stripped and cleaned it, reassembled it, and got it running. So far so good, nothing damaged AFAIK.  I was oiling the top jewel on the balance (the one in the cock) which was a slightly unusual shock setting. I removed the spring (3 leaves) which was part of a chaton holding the cap jewel. This left the hole jewel behind which I retrieved with rodico and then lost it. I was taking it off the rodico, very gently as I thought, with tweezers, and then it just disappeared.  Fast forward a week, I got a donor movement, non-running, with the plan to just take the shock jewel that I’d lost. It was the same movement but had standard incabloc settings, and was steel rather than copper/brass.  I changed the cock and balance complete and it ran, not very well. I switched the lower jewel setting, cleaned and oiled both jewels and the replacement balance. Without the pallet fork the balance swings very nicely with a puff of air. With the fork in place, balance out, it flicks side to side nicely with power in the mainspring.  Put them together and it doesn’t run. The impulse jewel sits in the fork and it stops.      Any suggestions how I proceed? In case you didn’t follow that I have 2 FHF70 movements, nothing broken as far as I can tell, but mixing up the balance wheels and jewel settings results in a non runner.
    • Oh and this almost perfect third wheel pivot and slightly set mainspring  Ah ok yes i see what you mean, good idea. I'll try that if i fluff this one up. The image isn't great quality but i like the idea though.
