I'm rebuilding an Elgin 683 grade wrist watch.  Don't know how I managed to miss it, but the inner most banking pin was bent toward the other pin.  Enough so that the pallet won't swing.  I didn't notice until reassembly.  Of course I moved it....Some......Before it broke off clean at the plate.
I suspect that was pressed in and with the right tooling a fellow could make one and put it back in there.  I simply found a cheap parts movement on ebay and ordered it.  Hopefully, it will be good.
But any ideas on how that might have happened anybody?  Could that happen in an ultrasonic bath?  Seems unlikely to me.  Some guy put it back together that way and it never ran again?  I'm awash in curiosity.  Other than rusty stem and setting lever the watch was in very good condition as though it had sat for many years.
Edited by nichod
misspelling
Hi, Hopefully the coming mainplate is in good enough of a condition, to replace the old one, so proper escape can easily be adjusted for, though old American pocket watches are said to be less sensative than swiss, so far as banking pin positioning.
Keep us posted on how the repair goes, please.
Regards
I’m sorry to say, in the field of watch repairing you are likely to come across all manner of bodge ups. Some will properly blow your mind.
I just hope that couldn't have happened in the ultrasonic cleaner.  It would have to have been a bridge striking it and the bridges are very light.   This is a very small movement.
(That pallet fork is the smallest I have attempted so far).
If you're 683 grade wrist watch Is like the one found at the link below you have movable banking pins. That means you can unscrew the broken one and replace off the movement you are getting. Unfortunately because banking pins can be movable people feel they should move them and on rare cases if moving them around didn't make them happy bending them is the next thing somebody does.
Then there are legitimate reasons to bend a fixed banking Pin and for that the Swiss make a tool I've attached an image of that.
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&0&2uswk&Elgin_683
Wow.  I wish mine was like that!  Alas it is not.  Mine are smooth on the dial side of the plate and almost appear to have been peened into position.  Perhaps it could have been rotated from the top which would mean it probably just rotated into the bad position.  Probably exactly what happened!  I might have twisted it a bit and returned it to normal.
Oh well.  I'm still learning.  I've a number of pocket watches with slotted and rotatable pins but it just never occurred to me to try and move them in that way.  I recall de Carle's book and the picture of bending those pins and I gave it an ill fated try.  Guess that's how we learn.
Thanks gentlemen.  I'll have the watch on the  "Watch of the day" thread one day.  I swear it!
Regards
Got the parts car today....Interestingly it is a close serial to mine but a year or two older.  The pins are apparently pressed in with no sign of the other end on the dial side of the plate and obviously no screw slots.  Also they are straight so no adjustment would have been possible.  My old movement's pins were curved.
Nice parts, but the pilot hole for the pin end of the stem is missing, appears to have been a bodged repair whereby someone ground the plate away and stuck a chunk of metal in it's place with a ready made hole...   OK.  Maybe I can do something similar.  The stem was broken flush with the movement.  Whoever had it must have been hell on stems!
Is there a mathematical formula for how many movements a fellow would need to purchase on eBay to finish a watch?  Variables would likely be related to age of caliber and amount available to spend plus or times the total desire to see it play again :pulling-hair-out:
It is a corollary  of Murphy's  law,where the chance of the bread landing jam side up is inversely  proportional  to the price  of the carpet.
Edited by yankeedog
Grammar
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
