Smoothing versus cutting broaches: Do I need both?
rduckwor
You don't need a  smoothing broach for a hand. The smoothing broaches are for smoothing the in side of a bush. These ready to use bushes, the brass is so soft a cutting broach is all you need, if you look in side the bush after cutting it is left smooth so much it looks as if it has been burnished. That is all a smooth broach does, is burnish.
Always use good broaches, they will always keep there cutting edges. Cheap won't last long.
4 hours ago, rduckwor said:
I need to clean out the pipe on a second hand.  Smoothing versus cutting broaches?
Thanks,
RMD
Well, A cutting broach will, of course, make the hole larger and so if you wish the hand to still fit the pivot then smoothing broach is the way to go, depends on if you want to remove material or not ;) but be careful, even though they are smoothing broaches they may still bind in the hole as you turn and you run the risk of breaking the hand.
To be fair, I have found smoothing broaches useful for clearing out stubborn debris. I remember finding what I suspect was glue in a seconds hand pipe once and couldn't use acetone due to the hand being painted.
@rduckwor I have merged your "dual post" as it keeps the forum cleaner. Kindly be patient in waiting for other members to respond rather than opening new topics with the same subject matter - many people are on different time-zones - have jobs - or are simply spending time with family ;)
    correct me if i am wrong,  broches come in a set.   "roughing and smoothing".   vin
30 minutes ago, oldhippy said:
Normally in sets. The very large clock ones can be bought separately.   Interesting to read Marks view about glue in the pipe, not come across that before.
'nor me since! Some silly sod's attempt at securing a loose fitting hand. Granted about 15 odd years ago but silly stuff sticks in the mind :D
I have use a pin vice for chronograph second hands, you can do it, but only if you are talking a couple of hundredths of a mm.
Go slowly tighten only a little bit and test fit, easy to close it a bit more, real PITA if you go too far and have to open it out again with broach.
Bergeon of course sells a special tool to do this if you have a few hundred pound spare, else get by with a pin vice, just make sure it is a good quality one that closes evenly so all sides (or 4 spots evenly spaced) get closed in evenly.
Ugh.  I see broaches are not free either.
Something else to add into the "Want List".  Projects get set aside until I can get back to them and I am running out of room as I go broke!
But I'm having a fantastic time.  Thanks Mark!
    • Next is to drill the screwhole this then provides an anchor point so the bridge doesnt slip around while scribing the shape. A cork lid, a pin and a piece of gaffer tape ( 😅 ) keeps it all in place. The hole is measured from the broken part using a hand measuring gauge. Mark the hole, punch it and drill it off to size. The awkward bit is working out where the jumper should be and the detent positions.  I remember watching a youtuber a while back do this with dividers, so i dug out my old school compasses and improvised a little. This bridge only has one hole and to find the detent positions you need two points of reference, so i just worked the second point from one of the corners, hopefully its near enough. Then scribe in the jumper using the two detent positions ( wind and time set ) that were marked and a big picture of the complete spring to look at that helps to give you a feel of where the jumper should be.
    • Right now I'm making do with a similar micrometer (the one below is $45 shipped but you can find better deals) and a $20 stand. You do have to be excruciatingly careful measuring jewels, since there's no table, but if you don't have the $500 to throw around, it's a nice option.
    • As  I kid, I'd watch Godzilla stomping over buildings and cars and I'd think to myself: Tokyo is a really dangerous place to live... . Cool watch!!
    • Next one up an AS 554, looks like a bit more to this one. First job is to check thickness, most springs are somewhere between .3 and .4, this one measures .35, that matches in with the .4 spring steel i ordered. So for marking up a permanent marker comes in handy to colour up the steel to be marked later with a scriber once its dry. Bestfit provide the extra bit of info for the jumper spring that is missing.
    • Thanks again, Marc.  Super helpful. I was wondering what the hole was for, and now it makes perfect sense. With your help and the other members here, it looks like I'm good to go with my Seitz tool set. I had to order some replacement pushers, but with those, the set is complete and in good condition. Now, I need to figure out what tool to buy to measure jewels (amongst other watch-related parts). I had my eye on the JKA Feintaster micrometers, but people get crazy bidding on them for $400-600 USD. I was thinking of just a regular digital micrometer (Mitutoyo). Thoughts?  Mahalo. Frank
