Seiko 6309 - balance diagnosis
Khan
Hello
Thanks to helpful members here, I managed to dismantle the dial followed by servicing the movement. While final testing, I experience lack of swing in the balance wheel (as before service as well). I can't see any visual disalignments or damages. It behaves as if it was gummed up, even though power in pallet fork. Note that it runs freely when lying upside down on the bench. I'd be very thankful if someone can spot the issue.
Kind regards
Khan
Edited by Khan
Hi Melt
Yes, the train runs freely when pallet fork removed. The way I clean it is by bathing it in alcohol, lift the wheel and use a blower. I removed the diashock jewel but couldn't remove the jewel from its rear "cover", don't know the trick without it flies across the room.
Hi Nucejoe
It runs in a low beat - barely a quarter turn right/left. The impulse jewel looks intact to me. My local watchmaker couldn't see any faults by visual check. But he didn't removed the balance from movement for further analysis.
Hi khan,
To check for in beat position of the impulse jewel;
I set the piece on bench dial down (DD), let the balance come to rest, keep an eye on the fork whilst slightly turning the BW clock/anticlock direction. Impulse pin is in beat if a slight move of the wheel causes the fork to move. if not in beat, bring the impulse into beat position by moving the stud arm, mobile stud carrier on your movement is to facilitate bringing the impulse jewel into the right position to receive energy from the fork horn.
Another method is to check if ,( impulse jewel ,staff pivot, escape pivot fall on a streight line.
12 hours ago, Khan said:
...The way I clean it is by bathing it in alcohol, lift the wheel and use a blower...
Probably not directly related to the lack of amplitude you're experiencing, but if you are talking here about the balance wheel I recomend you not to use alcohol to clean it nor the pallet fork, as it might melt the shellac that glue the impulse jewel and the pallet stones in place.
Low amplitude can be caused by quite a few things as others have mentioned, also wear or faulty pivots, dirt or improper oiling. I hope you didn't oiled the pallet pivots/jewels, did you?
Edited by aac58
Balance pivot dose look worn short in the pic. @Khan what lubricant did you use on escape teeth? Suppliment power manually to compensate for MS.
If it runs fine dial up but doesn't dial down high probability the balance jewel on the dial side is dirty. You need to clean/oil that again.
Another issue you can check is if the hairspiring is out of flat. Look at the balance while installed on the movement.. it should be parallel with the balance spokes and the whole movement in general. If it is slightly tilted it will hit either the underside of the balance cock or the balance itself. This might only manifest itself in one position.
Good luck.
Anilv
  • Thanks 2
Hello all
Thanks to all the constructive advices -
I removed the pallet fork (no lubrication in the top/botton jewel, but moebius 9415 for pallet stones on the way) and installed the balance and it has the same slow swing rate. I re-cleaned the diashock jewels in isopropylalcohol (any better cleaning alternative)?. Now it´s swinging freely and much better! + - max 10 sec per day when laying down but loosing 1.5 minute per when upside down according to my clock tuner app. I think the hairspring is few degrees out of level, see attached image.
Edited by Khan
Did you remove jewels to clean? Peg the jewels?  How do you know if all dirt is removed?  I guess not.
If you will, just drop some naphta on top of both shock springs, and fork pivots.
you are likely to witness excellent amplitude, whcih means jewels are not clean enough. If the cause of poor amplitude is not found right there, we move onto checking other possible causes, like impulse not in beat, HS rubbing etc.
Regards joe.
Regards joe.
Hi Joe
You were right. The issue was decades old stuck oil in balance top/bottom jewels, on which I had to use pegwood a couple of times. Even the caps were stuck and not easy to remove. Now it's running and keeping time well!
Edited by Khan
:Bravo::Bravo:
Hi Joe
Thanks for letting me know, A drop of naphta, deisel fuel, avgas etc on jewels, temporarily frees the pivots which may be stuck in dried oil.  I recommend making a habbit of its use to anytime we suspect a lubricant issue.
I also recommend finding and fixing as many faults as we can, prior to final clean, But I am self though so not all my techniques may agree with scholastic teachings. Regards
Edited by Nucejoe
Oh
Glad you have it going. I had same problem cleaned the jewels without removal and did no difference. Had to remove them and clean properly, that worked. Just shows how sensitive the Balance is. I use alcohol too, well the 99% isapropyl, the other in Bottle is for de-stressing :sleep:
    • I did that also for a few movements - well, mainly in/around the train jewels. I made big efforts to epilame the mainplate WITHOUT getting Epilame into the Pallet fork jewels (where it's not supposed to be, right?). I made litte barriers with Rodico around that jewel and used drops from a syringe to apply on the rest.  However, I've now stopped doing this. For three reasons: 1. It's a hassle and consumes more of this liquid gold. 2. I didn't see the need when using HP1000/HP1300 lubricants and grease for most part. The two places where I'd use 9010 (i.e. escape wheel and balance) receive Epilame in specific places... or the cap-jewel-setting of the balance suspends the oil sufficiently be capillary action (see my "conflict" about using Epilame on the balance jewels).  3. Lastly, and here I really wonder about yours and others' experiences: I felt that applying Epliame to the train jewels left them looking hazy (borderline dirty) compared to the (painstakingly achieved) sparkly clean results of my cleaning process. I just can't help but think that the Epilame residuals would mix with the oil and cause more friction/wear. I don't know.    simple: it'll stay there. It won't move any further. That's exactly what is happening if you epilame a cap stone. You end up placing the 9010 right on top of the epilame and the oil will sit nicely on that spot.
    • There are some parts on Ebay for the seiko 6020A, it may just be a waiting game for someone to strip one down, NOS will be more scarce . K would strip your movement down to the module then start looking at other seiko movement to see if that coil is used, then seek out a seiko part dealer. Also Retrowatches youtube owner Mike may give you some advice try him on his site . He also hangs around amateur watchmaking groups.
    • I would agree, in order to work harden something you need to exceed it's yield strength when it moves from the elastic zone to the plastic zone and you get permanent deformation and work hardening which is fairly close to its failure point, relatively speaking and dependent on the material/alloy of course. In theory you can load something constantly within its elastic range and not suffer work hardening issues.
    • Probably easier to get a complete new movement - but CousinsUK list it as discontinued. Maybe someone on here knows a substitute movement ?
    • Any other thoughts on how I can get a replacement coil? Any “hidden” or unknown physical shops (in Australia or elsewhere) that might have them in stock (but not always online)?
