18 hours ago, TheFixer said:
After a mainspring for a Seiko 6119c
They have them at cousins but are a bit expensive £16.50p, however, I also found one at £7.95.
So my question is what's the difference?
https://www.cousinsuk.com/product/105mm-height?code=GR2534X
GR2534X £16.50p
GR25341X  £7.95p
I have consulted my "Generale Resorts"  book and it does not show a GR25341X but does show a GR2533-1X which is the same as the GR2534X but slightly longer 10,5 not 9,5. + slightly weaker 0.11 not 0.115.  Personally I would just purchase the correct spring.
Which year is you book? If you open the Cousins link above you will see, as I mentioned, that GR25341X has been added and noted by hand after the catalogue was issued.
In any case, again as mentioned already, that is not the correct MS for a Seiko.
That is indeed what I have done.:)
    • Once you are aware of the problem, you can adjust as necessary. I have a couple of the Omega 10xx, and they are not my favourites. They seem a bit flimsy and not as solid as previous generation Omega. But I think that's true of a lot of movements from the 70-80s. For me, the 50-60s is the peak in watch movements, where the design criteria was quality, not saving the last penny.
