I recently serviced a Rolex 1575. Everything demagnetized, clean and oiled. Finally I did some rounds of dynamic poising and got to this point:
Dial up: 305°, +2 sec
Crown up: 265°, 0 sec (I'm wearing the watch on the right wrist, so crown up is important to me)
Crown left: 265°, +2 sec
24 hours later I found this:
Dial up: 305°, +9 sec
Crown up: 265°, +7 sec
Crown left: 265°, +9 sec
I don't get it. Amplitude didn't change, poise errors as before, but a faster running watch. Of course I will correct this, but I'm curious and want to understand what has happened here. Any Ideas?
First measurement was made fully winded? Should wait one hour before regulation. And the final judgement is after one week on the wrist.
Congrats on those great results! However, I'm afraid I have no idea why you get the different rate 24h later. After a service, and if possible, I always try to wear the watch for a couple of days or so before I try to regulate it. I believe the lubrication of the watch needs to be somewhat evenly distributed before regulating. I saw an enlightening article about it here.
Wait, that's after 24 hours of running without winding, or after 24 hours, then wound up again? I would not expect the amplitude to be that high after 24 hours. As for the rate, in my experience that can shift easily as much as you have seen after a service. I usually let a watch run for at least a couple of days before doing final timing. Some calibers are worse than others!
Rolex 1575 is an automatic. It should not make a difference about how much power you have running through the movement. Did you use the correct oils, you might have used to much or to little. You need to let it settle down and then test, that will give a good average of the movements performance
Thanks for the answers. A more detailed description first:
I reassembled, oiled the pallets with 941 and let the watch run for 48 hours dial up.
Then I did the poising and after a full wind the first measurement on the timegrapher with result +2/0/+2.
Then I wore the watch (normal day in the company) for 24 h. Then after a full wind second measurement with result +9/+7/+9.
So maybe the mistake was to let the watch run static in dial up position instead of "shaking" it while wearing? Or the period of 48 hours was too short? Right now the watch is on my wrist and I am observing the "real" gain compared to the atomic clock.
5 minutes ago, oldhippy said:
You say a full wind. Isn't it an auto, Or do you mean one turn of the button. You know you cannot wind an auto fully up.
At assembly complete the mov't is fully wound at the ratchet screw. That fully winds automatics, and an automatic arm, or a  winder box does as well.
You cannot fully wind up an auto. that is why the mainspring has a slipping device. The spring will only wind so far before the action takes place.
No disrespect but I don't agree with what you say. When in good working order an automatic can be wound to its designed full capacity to provide the specified power reserve. I call this fully wind.
Then if the same barrel could be wound more for a small fraction of turn if the mainspring was to be hooked to the barrel is irrelevant. An automatic barrel is not designed or specified to work like that.
Edited by jdm
A fully wound m/spring in a watch movements it cannot be wound anymore. That can never happen with an auto because of the m/spring, after a certain amount of tension on the spring it will slip in the barrel.
Yes as I tried to explain above the automatic mainspring will be fully wound to its applicable specifications. No problem OH, we can agree to disagree, that's isn't even the topic subject.
Ha Ha Ha I know. Nothing like a good natter. See how long it take you to wind an auto up using the button. You will give up because your arms and fingers will ache.:D
Well, since you mentioned. I work mainly with Seiko, the 6R15 fully winds to 50 hrs power reserve with about 40 crown turns. The 4R36 has 42 nominal hours and it could take a bit less, I should check.
Sorry again for the thread hijack.
34 minutes ago, oldhippy said:
I didn't think Seiko automatic movements wind up from the button?
It depends on the mov't. 7S26 and its direct predecessors don't. All the others do and you might be surprised to learn that they hack also.
Well, I don't know the official terms because I'm only an amateur. What I meant saying "full wind" on the 1575 (which is of course an automatic) is: I turned the crown about 40 revolutions so that I'm absolutely sure the mainspring is in the "slipping area". Thats "full wind of an automatic" for me.
Status update: After 30 hours the watch is 11 seconds ahead of the atomic clock. So the "about +9 result" of the timegrapher seems to make sense. I will observe until sunday evening if this is continuing.
    • Hi 122146 - welcome to WRT 😊
    • You could try a soft-solder repair on that
    • Hi Logan, welcome to the forum 👍
    • So I recently picked up a slim 6105 which had a badly damaged dial (posted in another thread). I couldn't really live with that given I had another dial handy, also in not great condition but with added bonus of having a better lume job and actually being fully attached to the dial plate!  So what to do with that damaged dial - I tend to think they should be in watches. Well...  A 6105 mid case and crystal assembly punt arrived from Italy yesterday, which I've frankened back into a working piece with the dial... Damaged dial now sits behind damaged crystal in an original case, currently powered by 6106 (with a 6106 caseback on to reflect this... I've cleaned up the original crystal up to a point, but kept it fairly beaten to distract me from the dial, my markers and it's not very satisfying lume job - it's not awful but it's glossy which I don't like. Also has a 6139 bezel on it for now because that's all I could find - I couldn't live with it naked and don't mind it tbh, though will keep an eye out as ever.  So yes, here you go - another 6105 (almost!) back to life. I'll also keep my eye out for the correct movement and perhaps a better dial in time. Caseback might prove tricky/expensive. I know Frankens aren't to everyone's taste but I do enjoy getting these back into working form. Better a working/worn watch than a sat in parts draws imo. And the good news here is that, thanks to the repro service crown, this is the only one I have I could actually feel safe to swim in!
