Eta 2894-2
Hi all. I have a broken subsidiary dial pivot (hope that’s the correct terminology) on a eta 2894-2. I realise the chronograph module is supposed to be non serviceable but my research shows that there is a Swatch group company that does sell spares for this module. Can anyone tell me who this is please. Many thanks.
The module is manufactured and serviced by Dubois Depraz but I believe they only accept work from the dealers.. ie Omega or other brands that incorporate this module in their watches. Also they are not serviced per se , but replaced on an exchange basis.
Anyone else can confirm this?
Anilv
Well it depends .. ETA themselves have this movement listed on their chronograph selection nowdays.
https://www.eta.ch/en/our-products/mechanical-movements/mecaline-chronographs/eta-mecaline-chronographs-2894-2
If you push the technical Communication button on the site you will find the Tech sheet for it too.
If your movement is looking anything like the one above then getting the parts from a third part dealer I would look for them at https://www.cousinsuk.com
I attache a Picture so you can try to find the correct part.
Hope this helps you on your search..
33 minutes ago, Specializedjim said:
Yes that’s my movement. But I don’t think the part I need is listed. Can anyone confirm the name of the part I need in the picture attached from the chronograph module of a eta 2894-2. Many thanks for your help.
As mentioned above the module is made by Dubois Depraz not ETA, unfortunately you will not get help from them, that's the standard Swiss business practice.
Many thanks for the info. I’m a bit confused as to the manufacturer as I have been told the chronograph module is actually made by eta not Depraz. Any way that doesn’t matter I would still really like to know the correct terminology for the part that’s broken. Thanks again.
Unfortunately JDM is partly right the chronograph module has part number 8510 and is only sold as what ETA calls an "integrated part".
You have to be authorized by ETA to buy it from them but even then it comes with an hefty prize.
At Cousine you will find it as a "Restricted" part.
I think the best chance is to buy one "Second hand" but there isn´t any parts for it out there.
Used module:
https://www.hhcdsjstore.com/index.php?main_page=product_info&products_id=486718
New:
Cousineuk Chronograph Module Assembled, Height 1 ( 8510 ), ETA 2894.2 ETA289428510 (Restricted)
https://www.boley.de/caliber/watchmovements/eta/4873
http://www.startimesupply.com/merchant2/merchant.mvc?Screen=PROD&Store_Code=1&Category_Code=1H-Parts-Movt-IntParts-ETA-07&Product_Code=ETA2894-8510-H1
And a tech sheet with the correct partnumbers for everything except the chronograph module.
2894-2_Tech_Com.pdf
Thanks everyone for the great input.
I have now been able to disassemble the Chrono module, remove the broken item and after about twenty attempts learning a little more every time, put the module back together and it works!!
So if I can’t get a new part the next question is, is there a standard repair procedure for repairing a broken shaft/spindle in a part like this (please see picture). I am a experienced engineer and have access to all types of machine tools thanks to my job. But before I start trying to reinvent the wheel I wondered if there is a proven method.
Thanks again for all the help.
If I understand right it's a snapped pivot, an experienced watchmaker would cut a new one on a watch maker's lathe and install it with a staking tool.
A general machine shop wouldn't be able to make a part that small.
FYI it's normal with the Swiss watch industry that one can't easily understand who does what. It's a thick web of contract work, patents and agreements made to their exclusive benefit. It has been like that since more than 200 years.
With these DD modules you need to dismantle with the chrono in the 'running' position to avoid parts flying off.
But you've probably figured that out already! I serviced mine when I had one .. more to see how it was constructed but after getting it back together I swore I'd never service (or buy) another.
Anilv
Many thanks that’s what I thought would be the method.
I work for a very large Japanese cutting tool manufacturer and we produce tools down to 0.1mm. Because of this I also have customers who have equipment to work this small so the size of the repair isn’t an issue. I may even manufacture a new part complete if I can’t simply purchase a new one.
Again many thanks again for the information.
You also have to measure the jewel hole to a precision of at least 0.01mm for the new pivot. It could also be made as an extension fitted on the existing body.
    • Just got these good quality diamond files from the bay for Just a fiver, we all love a bargain dont we. Brand names are J.K.Smit  and Triefus, two old diamond tool makers so not cheap crap.
    • Its a touch under ive just remeasured it and added a wrist shot. Unbelievably it was £13  plus 3 postage. You dont find watches that nice for that money every day of the week. Maybe removing the epilame in the oil region improves the purpose of it. We may know very soon as i emailed Episurf 4 hours ago to ask that exact question. 🤞they are happy to provide an answer for us. How do you fancy trying a stearic acid vapour treatment experiment  H .  Shall i have a go this afternoon ? Stearic acid experiment underway,  its started to melt at around  65° C. The idea is to find a large cap jewel to suspend over the vapour release.
    • That's the size of my grandfather's Ernest Borel watch. Definitely not a lady's watch! 👍
    • Thanks H It does have a big crown for the watch , it could be considered a ladies watch these days i guess, it measures 33mm case 36mm with that large crown 18mm lug space. A tad small for a guy of today, but still very wearable. The photo was deceptive so here it is adorning my 7 1/4 " wrist. It need some love to make it run better. The hair coils are touching so running a bit fast at the moment,  not caused by magnetism, and maybe just a clean and a service. The dtal is in fantastic shape.
    • That's one beautiful timepiece! Love the big crown in proportion to the case. Perhaps a ladies' watch, but I don't think so. I have a "modern Ingersoll" watch, but it has nothing to do with the original brand (Miyota 9015 movement). Interesting synonym for synthetic oils! 😆 There is, of course, a limit to how large a volume of oil epilame can bind and hold in place. If the oleophobic effect is too strong then it can become a problem. I'm not sure where I heard or read it, but as I understand it, the active ingredient in a bottle of epilame is extremely small and more than 99% of the contents of the bottle is just a transfer agent. If the active ingredient becomes too concentrated, which it can become over time, or if the product is of poor quality, the oleophobic effect is amplified. This in turn causes the applied oil to look like a gummed-up ball on the surface of the treated part. If that happens, we know that the active ingredient has become too concentrated. What we want is for the oil to bind but not to the point where it is formed into an excessively round ball on the surface. The highlighted text in the patent that you refer to describes well the problem that can arise with too high a concentration of the active ingredient. However, I would be extremely surprised if the entire amount of oil leaves the treated surface as water on wax would. At present, I am convinced that the analogy between wax and water on the one hand and epilame and oil on the other is incorrect. Epilame is described as binding and that is also my absolute experience. Epilame probably has some repelling effect but that is not its main purpose and that is not how epilame is designed and works. The method of abrading the epilame treatment from the section of the pallet stones coming in contact with the escape wheel teeth seems after even more research to be well established, but if it actually works, if so how and why is beyond what I can currently understand. Perhaps it is just to do and trust that it is based on well-established experience. I am, after all, inclined to think so.
