Have you checked mainplates side at 5hr and at 2hr for little screws holding the dial feet? If they don,t unscrew peacefully, put penetrating oil on them, let soak over night, sharpen you screwdriver to perfect fit.
If you can,t find the screws, give claiber post pix of MP sides( outer circumference)
Good luck
Edited by Nucejoe
At hr 5 and 10
Good luck
You are correct! Upon careful inspection, there are two screws at 180 degree position on the mainplate. Thank you!
