Introduction
Welcome, Paul! When you're new you will undoubtedly be asking many questions that have been asked before, but those questions aren't stupid but instead the most important ones, and will likely already have been asked. You may of course already be aware that you can use Google to search WRT specifically. However, if three is someone out there who would want to know how to, all you have to do is, for example, type:
site:www.watchrepairtalk.com ETA 2824-2
    • All I do is use a fine marker (sharpie) to put the service date on the back cover, this way it can be removed with some IPA and does no permanent damage to the watch. I'm in two minds about the whole service marking thing, sometimes it's good/bad to see the markings on the watch case back as you know it's been worked on and vice versa. However, if I took my car in for a service and the mechanic scratched some code into the housing of my engine I wouldn't be too impressed. Hence, I think my sharpie solution is a reasonable compromise.
