I was following this video to pop out the glass on my Geneva watch.
I wanted to pop out the glass to adjust the calendar frame. However, after popping out the glass,  the automatic watch stopped working. Could it be possible that the pressure of air from the syringe damage something? I appreciate if anyone can suggest possible problems. Below is my watch.
Thank you in advance.
My guess is that the dial lifted slightly and this has taken the pressure off the dial washer underneath, allowing things to get loose and the hands to stop turning. However this is only a guess.  Proceed with caution. Check to see if the dial feet screws are loose. Check to see if you can move the hands with the crown.
The picture shows dial is tilted,  so would be the movement usually. I cast my vote for balance wheel having come in contact with the case.
Set the dial/ movement level in the bezel.
Call me paranoid but I would not use the air blowing method on any watch (unless it had no small moving parts but what watch has that, right?).
I'd rather just use the claw tool to remove teh crystal.
32 minutes ago, Chopin said:
Call me paranoid but I would not use the air blowing method on any watch (unless it had no small moving parts but what watch has that, right?). I'd rather just use the claw tool to remove teh crystal.
Some crystals, like the one that is in the video and owned by the OP have absolutely no lip to grab with a lifter. So there is no other choice. Remember that our Mark is not in the business of teaching how to damage watches, but exactly the opposite.
You could try the carpet tape trick with that type of glass. It is not without its hazards mind you. I can see there is a potential to launch the watch and/or the crystal in to orbit, or end up with insanely sticky goop in places it really aught not to be, but I suspect it would work.
There are also suction cups specially made for this. I've never seen a report about their effectiveness.
    • Thanks for the replies! Here's a photo of the front of the clock and a GIF animation of the movement (exposed by removing the black cap in the centre of the clock). You can see the behaviour of the gears. It's a fairly valuable clock from the 80s (Braun ABW 35). I'm not sure if replacing the movement would diminish the value, so I'd prefer to keep the original parts if it's easy to fix. But since the movement itself is pretty generic, I guess, maybe replacing it wouldn't make any difference with regard to the value of the clock? Or would it? I suppose the value is mostly in the design.
