Slipping (out of position) clutch on AS 1171
That’s a great video - thanks for posting it. Sometimes to look forward too when I start looking at the ladies watch movements I guess. Although it’ll be a while before I get my hands on anything high-end I suspect.
Just arrived today with the case a little worse for wear so will probably just polish it back to the steel
I must be going nuts !! I checked the parts list to get a part number and see that there is no screw shown. Only a rotor assembly. I checked the rotor I removed and the screw is part of the assembly. What a stupid error Regards to all, Dave
This would have been seen before the fork and balance were even fitted if you carried out a test on the train wheel as a matter of course.
With the amphibia there's also the gasket in the screw-in crown. If memory serves a correct seal for the back of the case is tricky to find as well, but maybe that's because mine are vintage. The newer cases are larger I think.
