Indian Allwyn watches
Has anyone here worked on an Allwyn manual wind 17 jewel movement?
I bought one yesterday, (awaiting delivery), because the movement image intrigued me, the crown pinion doesn't have a screw head as you'd normally see but looks more like a rivet or Allen bolt with the hole but without the hex sides to it.
It's simple curiosity and being Indian and a bit different I wanted one for my collection and to see why that design when I try to strip it.
Apparently they were a collaboration between Seiko, possibly they didn't like hmt/citizen getting all the glory in India?
I suspect they may have a nearly identical clone Citizen 1802 movement to the manual HMT 0231 based watches, or perhaps one of the manual Seikos. I picked up a franken "Sieko" automatic which has an Allwyn automatic movement which is stamped A6319 - and is a clone or re-badged Seiko 6319A
Either way, I would expect it to be a robust, well constructed workhorse movement. Don't forget to post some pics when it arrives.
Edited by AndyHull
1 hour ago, AndyHull said:
Does it look anything like this perhaps?
If so it is probably a derivative of the Seiko 6310A
It does indeed Andy. Thank you.
I never thought of doing a search for Seiko movements to see. Bit silly considering I'd read that they were a collaborative effort and I knew HMT were a clone Citizen.
I'll share pics when it arrives.
    • I think that a 814/825 stem would work, there are a lot of compatible parts between these.
    • Hi everyone, I put together a Venus 178 recently, but found that the hour counter "creeps" ie. runs when the chrono is disengaged. This is the similar type of setup as the Omega 861, where the hour counter is driven off the mainspring barrel, but stopped when the chrono is disengaged by a friction spring.  Am I correct in assuming that the friction spring for the hour counter driving pinion should be dry? I am guessing that the issue will be either the spring or the driving pinion, but while the driving pinion has some wear the spring looks decent.  I've attached a couple of photos in case anyone has any tips. Thanks in advance!
    • Thanks everyone for the replies. It seems setting the hand is a bit of a guessing game, and I thought there would be a very specific way to do it. Since the reserve indicator hand moves clockwise as the spring is wound, I tried setting it right at the start of the black side. But setting it there doesn't really make sense, because by the time the spring is halfway wound, the hand is only at the end of the red side... In my head halfway wound shouldn't mean the hand is still "in the red."
    • Lovely part of the country! I spend most of my days driving along the A64 for work in and around York. I'll be sure to drop plenty of questions soon! I've actually got a couple of watches on the way that I'm pretty sure I'll need some help with! They look pretty beat up from the pics but I love a challenge and an excuse to buy more tools 🤣
    • I have two of these in my home. You need to remove the movement from the case, take off the hands and remove the dial and take a few good photos of the front plate so I can see what the problem is. The round nut unscrews and the hands pull off pull them off from the center and not the tips as you could break them.
