Intriguing ETA 2678 issue
What I'm confused about is the fact that with all the parts in place it only slips when adjusting the hands clockwise. If I adjust them counter-clockwise it works fine.
I'll try loosening the canon pinion... Out of curiosity what is the correct way to loosen such a canon pinion ?
Are you supposed to slightly pull the 2 tabs that hold the tube outwards or what ?
Also I still get the impression that the small steel gear might not engage properly with the minute wheel due to pivoting just slightly. Not sure.
Edited by Chopin
How come the screw is wrong ? How does the screw influence all this ?
What should I be looking at exactly ? How does one know that it's wrong ?
PS: that little plate (that covers the parts) is flat from what I can tell.
Edited by Chopin
lol ..no need to rip your hair off
Unfortunately I didn't have the ETA 2678 at home right now but as happens I got a few ETA 2671 whitch is the same movement except without the day indicator.
I guess the screw is the one I have circled in yellow , on these small movements they actually looks like this when they come brand new.
What you should check is if the day/date dials is moving smooth, if they dont then it might cause the stress to break a tooth on the wheel.
While your at it check the yoke action is nice and crisp, if it's weak the sliding pinion might just tuch the tips and that will break the teeth too.
Since you say it works when you take the cannon pinion out it might just be in the progress to change date/day and just got stuck.
Photo of the screw and plate.
It seems like this circled part below is moving just a bit downwards (talking about the tip that holds the gear not the entire part) but only when the hands are adjusted clockwise and only when it reaches the borken tip does the gear that it holds start to slip and not engage with the minute wheel.
Also, strangely, if I take a few parts out and put them back it can run well for a few rotations but then something goes bad and the issue begins to repeat. It's as if the canon pinion is smoother and then it becomes a bit stiffer...
Edited by Chopin
You shouldn,t pull the two tabs , oil the canon pinion groove that sits between the two tabs, instead.
Clean and lube the date jumper. The min train and date train + date jumper+ day change, should altogether turn nice. Excess resistance and unlevel min train cover/ bridge will cause one gear to ride over the pinion of the other, that has been the case here. I think Mark put some oil on top of min gear in between min gear and its cover.
    • Yes, I was referring to the (jewelled) gear train with HP (most of the time, I use 1300, but when Rolex says 1000, I'll use 1000).
    • did I miss the update of the message of something changing?
    • I suppose it would depend upon what your lubricating with those? for instance what does the manufacturer say about those lubricants? I have a PDF from the manufacture and a rather peculiar statement found on the bottom of the chart. my suspicion is the reason the recommending would be without epilam the HP oils like the spread except when they're in Ruby jewel's with steel pivots. tableEN lubrication 2020.pdf
    • These types of hairsprings become weak with age and very fragile. Which I expect it is that giving you trouble, and that wheel is not the correct one, if it were not bent I don't think the movement would run as the teeth are not the correct height. The problem you have is price which depends on you. It can be repaired but is it worth it to you, because there is little value in the clock. A wheel can be made and hairspring replaced. Or hang on to it and keep looking on ebay which is your best bet for replacement parts or even a complete movement but it will be like finding a needle in a haystack.
    • I did that also for a few movements - well, mainly in/around the train jewels. I made big efforts to epilame the mainplate WITHOUT getting Epilame into the Pallet fork jewels (where it's not supposed to be, right?). I made litte barriers with Rodico around that jewel and used drops from a syringe to apply on the rest.  However, I've now stopped doing this. For three reasons: 1. It's a hassle and consumes more of this liquid gold. 2. I didn't see the need when using HP1000/HP1300 lubricants and grease for most part. The two places where I'd use 9010 (i.e. escape wheel and balance) receive Epilame in specific places... or the cap-jewel-setting of the balance suspends the oil sufficiently be capillary action (see my "conflict" about using Epilame on the balance jewels).  3. Lastly, and here I really wonder about yours and others' experiences: I felt that applying Epliame to the train jewels left them looking hazy (borderline dirty) compared to the (painstakingly achieved) sparkly clean results of my cleaning process. I just can't help but think that the Epilame residuals would mix with the oil and cause more friction/wear. I don't know.    simple: it'll stay there. It won't move any further. That's exactly what is happening if you epilame a cap stone. You end up placing the 9010 right on top of the epilame and the oil will sit nicely on that spot.
