Hi all,
My name is Jim. I recently came into the possession of a couple of vintage watches and I’ve come across this forum as I’ve been trying to figure out how to get one of my watches running. I have zero experience with any of this but I’m very intrigued and admire your passion for watches and repair/restoration. I’m a woodworker by trade so I understand quality, appreciate the old ways, and really like vintage things, machines, tools etc. Thanks for reading!
my goal is to get the Timex in the attached photos running. I just think it’s very beautiful and the thought of some crappy quartz movement swap-out kills me. Not gonna do that!
Well dear friend you are welcome to forum...
First you have to get basic watchmaker tools like screwdrivers, tweezers and movement holder... You can find all on eBay...  Before attempting to repair, please watch Mark's videos with extreme caution...  Then make some practice on cheap movements, if you don't want to be disappointed with a simple fault. Especially if your watch is valuable...
Ask any problem you encountered and enjoy the forum please...
Emy....
Hi Jim, welcome to the happy factory. Loads of excellent advice on this forum from some really knowledgeable people. The answers are just a question away. When I said lots of knowledgeable people I wasn't including myself.
Welcome to happy valley Jim In answer to you question Regarding the Timex The member on here with the timex knowledge is Jerseymo who has all the service manuals etc. As Asmobrat states before delving in first look at Marks videos and get a handful of reasonable tools, screw drivers tweezers and loupe or two to start with.  Timex were designed to be cleaned as is, removing the dial and hands just leaving the raw movement, Cleaning with benzine, Lighter fuel, or carburettor cleaner blowing dry with air and light lubrication (use the correct oils) anything other will lead to problems in the long run. Having done all that enjoy the experience. Any questions just post them we are all here to help
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
    • No, I now realise it’s broken😥 ive looked for one online, but v. Expensive! im going to service as is, in the hope that  one turns up. Thank  you.
