hi again
I got this seiko 7s26 of eBay spares and repairs and manged to fix it
The only thing is the Dial is badly scratched and has a circle scratch in the light where the hands where crushed
I manged to cover the main scratch with a blue pen but it's to dark
My eyes are like super good
So I really notice even the blue is wrong
Can anybody point me to this dial for sale anywhere
Cheers
Search ebay with the complete model number from the back cover 7s26-xxxx. Or just search google and see what shows up.
Sent from my iPad using Tapatalk Pro
I really want the same dial that bad
I absolutely love the watch and the dial is what makes it for me
I brought a green military Dial and some new hands but don't want to use the dial it just won't suit it at all after how good the watch looks now
Looks like you've got a 7S26-0020, that is an SKX007 / SKX009 "true" diver, which the Pepsi version has the last 20 minutes colored differently on the rotating bezel, to hint about usable air range. Needless to say, a colored range on dial doesn't really have a function on a diver or not, it's purely aesthetic on the so-called "speed racer" models.
Suggest that you look some of the million pictures about your watch in it's original form, which in my opinion looks superb in either black or Pepsi variations. Parts to restore it can be easily found.
Otherwise a brand new SNKK27 is just $64.30 on Amazon.
Edited by jdm
Hi    Thats a cracking watch, pity about the dial, Myself I would try a better repair check through artists colour charts and maybe by mixing colours you can get a close enough match. If that fails then by all means continue the search.  I like to keep watches and clocks as original as poss not always succesfull
I want the Watch to stay as is just with the same dial in good condition
The pics really don't do it justice when it's on your wrist it's amazing
The photo is what it was like when I got it broken
If anybody knows if you can get the same dial on its own that would be great if I have to buy the same watch then I might do in time
Also if my eyes where bad then it might not effect me. But my eyes are just drawn to the damage
Not to hi-jack the thread, I took the liberty to post a picture I took of an original SKX007.
It's (I believe) the most popular mechanical watch ever, and the most commonly "modded".
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
