Is this a good way to clean a Quartz movement?
Cleaning the a watch movement
Watches accumulate over time dust and small metal debris inside the movement. All watches have a friction fit to allow you to change the time while the movement is running. If there is oil on that friction fit then the movement will not be able to drive the watch hands any more properly. The friction fit will slip and the time will be off. A quartz watch that is off by several minutes per week has usually mechanical problems, not eclectic problems.
Quartz movements are more simple in their mechanical design. They have very few cog wheels and it's easy to get to them. This open design does often allow you to wash the movement in lighter fluid without taking it apart.
Lighter fluid to clean watch movments.
To clean a quartz watch you just take the movement out of the case, dip it in a small bowl with lighter fluid and move it a bit left and right to allow for the flow of lighter fluid through the movement. This will wash old oil, debris and dust out of the movement and you will find small particles at the bottom of the bowl.
I have installed a new battery just a few month ago and now the watch needs again a new one
If you are sure that the battery is was of good quality then this is probably a sign of oil in the movement getting old and sticky. The friction in the movement has increased.
An easy way to fix this is to first apply a bit of very thin Moebius quartz oil. After that you wait a few days (watch running) until the oil got into all the pivot holes where it dissolved the old and sticky oil. Finally you wash the excess oil away with lighter fluid. Just wash the entire movement in lighter fluid. Traces of oil will remain in the movement and that is enough. You don't need to take the movement apart for this procedure.
I would say no.
Dipping the movement complete is a bad idea.
Quartz watches have many plastic parts in them that may react badly to lighter fluid, also it will not clean the pivots correctly.
I personally think that pretty much everthying above is bad advise.
Quartz watches still need to be dismantled to clean and oil correctly.
Maybe if its a $2 watch and its not worth the time to service it correctly and you just hope to get a few more months out of it the above might be worth trying, but other than that I advise against using teh above cleaning instructions.
Tmuir, I heard the fluid may actually hurt the circuitry, in some cases the movement will run  but drains the battery within a few months. What is your thought on that.
The very few quartz movements I have overhauled, it is been complete tear down, brushed parts in friendly fluids and oiled as if mechanical. The result have offcourse been to my satisfaction. But wouldn,t that defeat the idea of quartz accuracy and no repair pain? Or is no repair my overexpectation.
Joe
Joe
I suspect a tongue-in-cheek thought when you posted about the no repair expectations for a quartz watch. Many quartz movements were designed to be serviced. One of my quartz watches sports a 13 jewel movement. Unfortunately, economics gets in the way. A complete, new, 13 jewel Ronda 5030.d movement, Swiss made, can be had for less than $50 USD. A Swiss Parts version, 6 jewel, can be purchased for less than half that amount. I don't personally know any professional watchmakers who will disassemble, clean, oil and reassemble a movement for $50, much less $25.
You're going to see more serviceable quartz movements if the Seiko produced meca-quartz type catches the public's attention. It is a hybrid chronograph at this time. The 'engine' that provides the motive power is quartz but the mechanics that power the chrono functions are all mechanical. You gain the satisfying feel and operation of a mechanical chronograph while powering it with a stable, long lasting quartz power source. Win/win.
Don't get me wrong. I'm not predicting the demise of the mechanical watch movement at all. Merely another way to produce similar results.
Edited by TexasDon
I agree it could damage the circuitry, it could also shift oil and dirt onto the tracks causing shorts, also if there is any metal dust within the movement cleaning it together could shift it towards the rotor where it will stick causing other issues.
Quartz watches still eventually need servicing, its just a lot of modern quartz movements are made not to be serviced.
My daily wear watch is a Seiko 7546-8360 quartz watch from 1978. It was bought non functioning but it just needed a strip down clean and oil and obviously a new battery. I'm pretty confident that's the first service the watch had and it probably wont get another one for 10 or 20 years.
As TexasDon states if you want the movement to continue to work it still needs to be correctly serviced, but the cost to service compared to replace means it usually doesn't happen unless its a high end movement.
Edited by Tmuir
7 hours ago, Tmuir said:
I would say no.
    a good cleaner is alcohol!  find it at rhe chemists shop.  vin
I am inclined to think alchohol would pose the least or no risk, especially if a quick dip,  evaporates real quick.
TexasDon, no tongue in cheek, seriously, I got a watch that started draining battery following such a dip, I was being told the fluid damaged the circuit, some say a short circuit somewhere, fifteen years on I still don,t know the real cause. So I asked.
I still got the watch, kappa brand, swiss EB, metal gears and big jewels looks pretty too. Can I interest you in a trade off, goat for horse .:lol:
Regards
I'm not sure if lighter fluid will affect the circuit board, but I suspect not, however it may dissolve some plastics, and soften others, so I would be a little cautious when using it on quartz movements.
Isopropyl alcohol (aka isopropanol)  might be safer, but then again, it might not be as effective at dissolving the build up of oily grime.
Back in the day, we used to use 1,1,1-trichloroehane to clean circuit boards, and as a degreaser, but that is an ozone destroying solvent banned in 1996, so unless you have some lying about, then you will need to use something which is most likely less effective.
I have used isopropanol extensively over the years to clean plastic parts, and remove soldering flux residue and other grime, and it is reasonable effective in most cases. I am not aware of it damaging plastics, but I guess the proof might be to sit a working quartz movement in some for a week, then remove it and see if it still works. I suspect it will be fine.
    • Hi, this is the first place I found when looking for advice so I hope someone could advise me.  Im completely new to touching watches but I’ve always wondered how they work.  I’ve bought a cheap movement, an ETA replica to take apart and rebuild.  Im thinking I’ll need some screwdrivers, tweezers, movement holder and a loop? My goal is just to have a go first and see if I enjoy it enough before buying more tools.  Do I buy cheap tools for now and get better quality tools later if I enjoy it like I think I will? or will the cheap tools be a pain and take some of the fun out of it?  With quality tools being relatively expensive I’m unsure what to buy.    Any advice would be greatly appreciated!
    • Yeah I have seen 44-56 documented for Elgin 18 size elsewhere. I have the style of gauge that's like a set of feeler gauges and I never noticed before today it is faintly stamped "Elgin". Pictured is the way I have been measuring. I am going to go to a larger jewel than the 42 that had been in there. I recently won an auction on a big set of Fitrite jewels all in the little bottles, to discover that the what's actually in the bottles bears no relation to the chart of sizes printed on the box. In most cases it seems to be all mixed so in fact I have about 24 little bottles and thousands of assorted jewels of all diameters and lengths, which is better than nothing. But since I don't have a micrometer with a table, measuring for the exact diameter will be a big job. Instead I will test a lot of them in the fork slot the same way I measure with the gauge. But this is still the next thing. I have to get the escapement to unlock first.
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
