I have an issue with an antique Hamilton 974 pocket watch (circa 1912). The watch has been recently serviced including jewels and gears inspection, new mainspring, cleaning and lubricating. Balance wheel swings freely with good amplitude (270 degrees), beat error is 2.4ms (can be improved), the rate after some adjustments is now fairly consistent in all positions.
The problem shows on the timographer as slow but regular oscillation of the rate. The oscillation cycle is exactly 5 minutes. The maximum difference in rate between low and high is approximately 30 seconds per day. During the slow rate of the cycle I can also see lower amplitude (250 degrees) and an increase in beat error to 2.7ms.
This watch escapement is 18000 bph. The only gear that rotates close to 5 minutes is third gear which, however, makes one rotation every 7.5 minutes. Anyway, just to be safe I replaced the third gear but the problem remained.
What can be the cause of such a behavior? What kind of defect can produce such a cycle?
Or, perhaps it's just something that might occur in an antique escapement? "The nature-of-the-beast"?
I've seen this before and I agree with nickelsilver It's the teeth of the barrel mashing with the pinion of the center wheel.  The watch I had somebody had substituted a different mainspring barrel and it was a very severe issue until I got a replacement barrel. Basically couldn't even time the watch at all.
What's the tooth count of the barrel and center pinion? I'm suspecting a depthing problem due to worn center plate and bridge holes.
I agree that this is his problem. he probably has a pivot or two of worn on one of the wheels . Unless it is a tooth of one of the wheels that is worn and that the watchmaker has not seen. It happens sometimes too
I haven't thought about that. I have have another barrel and a center wheel, so, I will be able to swap those.
Before swapping the parts why don't you look at what you have to see why they're not working?
Then parts swapping on American pocket watches? On modern Swiss watches you can swap just about anything they interchange. But you want to be really careful with parts swapping on American pocket watches because a lot of times the parts were hand fit. So swapping your way out of a problem may actually make new problems. Which is why we need to find out why the current parts don't work?
American movements especially after the turn of the century were completely non-hand fitted. What can crop up is differences in grades for the same base caliber. But a part for Hamilton x caliber will fit x caliber.
   not true;  vin
   not true;  vin
Not sure on which point you disagree but interchangeability was the corner stone of U.S. watchmaking. That said many of the movements have been massacred so maybe a jewel was replaced with the wrong one and the pivot adapted or a fork that was close mashed in somehow, etc.
I've been across the pond a couple of decades but still see an American pw here and there. Last was a "maker" who recased old Elgins in wristwatch. Customer brought two of them for service (they were supposedly restored by the "maker"). Broken hs collet glued, escapement berzerked, dial glued on, balance pivots grooved, holes smashed closed, not untypical of stuff I saw regularly 20 years ago.
But aside from maybe Howard or some of more boutique manufacturers no way they were hand fitting parts at Waltham Elgin Hamilton with the production numbers they were hitting. The finishing techniques for pivots for example may have been labor intensive but they were made to standards. The U.S. smacked the swiss so hard they had spies bringing back intel on manufacturing methods. Which they improved upon, and eventually smacked back with.
The reality versus the fantasy of interchangeability of American pocket watch parts? By the way if you haven't seen the video below it's quite interesting from the 30s. If you look at the video one of the reasons Elgin made so many watches was its factory was really really big. The number of people was huge was probably one of the largest companies in the world at one time as a guess. Multiple generations of Elgin families worked at the factory. So by the 1900 production methods improve machinery improves Elgin takes great pride which you can see in the video and making sure everything fits perfectly. But still a lot of and work hand fitting hand adjusting with a huge volume of people.
So the problem with this conversation as we can all pick and choose examples to make our point which doesn't necessarily help with the original problem. For instance the second link turn-of-the-century mass-produced watch. Made for a whole bunch of years listed as a model three. Go to the website you'll find a lot of 12 size model three watches. Illinois parts catalog is rather interesting the parts are listed by name of the part then on the page illustrations the size and then the model. Canon pinion for 12 size model 1 to 5 all identical. Only one part numbers listed reality they do not interchange. They may have been mass-produced in a turn-of-the-century factory but notice how there made in batches. There's still a lot of hand fitting and adjusting true they're going to be better than cottage industry European watches but.
So back to the original question swapping parts to fix the problem is a bad idea unless you know why your swapping the parts. So we think we know where the problem is let's look at those parts to see why there a problem. Then once we figure out why you have a problem what the problem is then we can figure out how to solve the problem.
https://www.youtube.com/watch?v=ys4ChOWYNy8
http://illinoiswatchguide.com/gradeautocrat.html
   here is a story about Swiss made watches -- i heard -- it may be true:  they boasted making "the smallest watch screw" and sent it to Japan.   the Japanese drilled a hole thru it and sent it back to the Swiss !    vin
Iranians tell a similar story , Britts made and sent to Germans, a wire placed inside a strand  human hair,  Germans drilled a hole in the wire, stuffed the hole with human hair and returned.
Well, I buy non working American pocket watches, sometimes even missing parts, and resort to swapping parts routinely to get them fixed. In rare cases I have to make the part that I need because I can't find those ready available. It gets sometimes very challenging and often frustrating, but it feels good being able to make a balance staff for an old 18s watch based on hand measurements and eyeballing of what's available (old, broken staff, etc).
In the case of this watch I swapped(!) the center wheel and the problem just went away like magic. No more cycling through the rate. There is still some irregular cycling of just a few seconds/day, but that is pretty much expected on those old watches. I've used the opportunity, with the balance out of the watch to improve the beat error down to 1.6ms - I am totally happy with it. Thank you all who suggested the cycling problem to be caused by the center wheel pinions or the barrel! It was.
What I heard (60 years ago....)  They threaded it and screwed on a nut.  At one time the story involved The Americans and the Swiss.  Had to be true at some point :biggrin:
    • I was wondering because of the alum idea.
    • just a reminder about this test is it's not a perfect test it's a quick test. In other words you can adjust the banking pins that are both the same and visually this test will pass everything looks the same but both banking pins can be in the wrong place. although the majority of time when people are playing with banking pins I don't put them in the same place. one of things have to be careful of is I believe some of the pallet fork measuring tools that actually give you the roller jewel size are actually size so that I get confused? What I mean by this is if you inserted a whatever size in and are always told to go a slightly smaller I thought that the gauge itself its number corresponded to give you the exact number. So a lot of it depends upon the gauge itself I think you do want the roller jewel slightly smaller because it does have to fit in the slot and it does have a little bit a play. But if it's too small you will lose energy so does have to be sized right. Oh other things to check is? I'm attaching an Elgin sheet on checking the escapement I've seen references in the past to making sure that the slot in the four corn is nice and smooth and apparently you can end up with a rough slot and then the recommendation is to polisher clean that up. Not sure how well that's really going to work even if it has been the recommendation of other reference materials. yes art full plate watches fun when they don't work. This is where it's nice to have another set of eyes sometimes as maybe they'll find something you didn't  although that can add other issues. The owner of the shop provides himself on his skills of so now two of my watches have relocated to his bench to solve problems both real and imaginary I'm sure that will get fixed eventually hopefully. But still sometimes another set of eyes might see something that you're not. yes this sort of thing can be quite frustrating. Also makes for an interesting problem unless of course you're the one trying to solve the problem that it's a Escapement Elgin setting up the escapement.PDF
    • I’m not to sure mate! I’ve sent a picture! The crown is off a Tissot 1853 automatic limited edition T115427 A GP19 moto go watch!
    • For years and I'm still using it I've been using something called SeaMonkey? It's a Mozilla product Basically outscore its Firefox plus an integrated email program. But not the same problems here a lot of times when things are upgraded they tend to be now aimed at very specific browsers like Firefox so I've had to switch to Firefox to respond to any of the messages on the group. So yes they do seem to be getting more browser specific and that may be a reason for others having complications especially if whatever you using hasn't been updated. So yes the world is getting more browser specific perhaps for security reasons. Even though I use a product that is updated on a regular basis is still has problems. So whatever you using for browser should be up to date and if is not recognized it's going to be a problem.
    • I did remember to ask at work and minor complication? Well I suppose technically two separate complications. First off glass mineral glass versus Seiko's Hardlex Glass. Don't know if other companies have their own class or not and a basic class for crystals is probably not the same as window glass it would be more transparent. It becomes obvious if you're looking at a sheet of flat crystal glass versus window glass it's definitely more transparent you can see it when you look at the edges of it window glass looks green. No idea how that changes physical characteristics other than optical. Then we also have thickness like the Seiko five's there crystals are really sick compared to other things and I'm guessing that makes things different. In the first link it talks about Sapphire versus mineral glass. One other thing is bothering me though when I'm reading this is where is the source material? What I mean by this is could we end up with multiple generations of salespeople quoting the same sales tactic or information and we don't actually know because you don't have a source reference? Let me quote something off the website it's brittle oh dear I was sad? Except it's not immune to damage it can crack where shatter under extreme force or impact. So what is the definition of extreme force or impact? Then is that more or less extreme then mineral glass?  Then regarding the price difference while back I had asked the owner where the Sapphire came from and basically wherever he can get the cheapest. So typically ordered from a variety of online supply watch parts in the US and  aliexpress China.. Then yes it does make a difference because we go through a lot of glass crystals and sapphire https://thehorologylab.com/sapphire-crystal-vs-mineral-glass-which-is-best-for-your-watch#google_vignette Then I guess one is glass not glass when it goes by another name? Hardlex Looks like it's purely a Seiko product but now I wonder if other watch companies have their own special glass? I didn't remember from past experience my favorite was people exposed to welding you can find little blobs a metal stuck to the watch case the crystal still intact but there's little burnt holes were bits of metal had actually burnt into the crystal but it was still there. Okay website below starts off with Sapphire sounds good but Apparently it can shatter easier then Hardlex. https://theslenderwrist.com/hardlex-crystal/ One other thing is what I'm reading to websites would be back to I want to see the test results? Often times weren't looking for a subject will find websites where I basically called them these are better than that by the way but sometimes I'll find websites that I will call book review websites were basically the review other websites other material and don't really introduce anything new to the subject. As I said these websites look quite nice which is why I'm giving you a link but where's the test results the definition of extreme how extreme to break a sapphire versus a glass or Hardlex?
