What is this bezel part?
Lc130
Hi All
I'm a beginner.  I was just about to recase a movement when I noticed this bent ring in the case.  I haven't tried to remove it.  What's it called and is it part of the case or part of the crystal?  I did notice that the old crystal, which I was able to push out with my thumbs, had a slight lip at the base.  This is a Waltham from late 60's early 70's.
Thank you
Charlie
Edited by Lc130
I suspect it is part of the case, though not necessarily an integral part. By that I mean it can be replaced, hopefully. I don't think it's the tension ring from the acrylic crystal, as these are on the inside of the crystal, and wouldn't have contact to the case.
I was afraid of that.  The metal seems to heavy to be part of a crystal.  I have one "armored" crystal in desk and the armor seems meager.  I think I can bend down the lip created by using a crystal press.
That missing "ledge" is from 5 to 7 o'clock position.
Would I use a compression fit, glue in, or some other crystal?  I've not gotten to crystals yet as this is the first watch I haven't mangled during my learning.
Thank you
I'm just as much a beginner as you are, so I'd be out of my depth giving advice on how to proceed. I've never seen a flange or lip like this, but that's not saying a lot (Dennison). Does it look like a separate part? It looks like it to me from the close-up. Slightly different colour, and an edge to it. I have no idea where to get a replacement though, or how to fit it.
If an experienced member doesn't come along soon to offer some useful advice I would ask Simon on The Watch Forum UK, or contact RePLATEit in Canada for repair advice and a quote.
I'd be interested to hear how you get on.
    • My mentor has been using one of the Chinese clones for several years. Seems to work very well. Just put the object you wish to demagnetize in the centre of the cross and press the button. One word of caution though, the quality and QC of Chinese clones can vary a lot. You'll never know whether you got a gem or a lemon.
    • You could also use a very fine artist's brush to brush between the coils.  If you get a size 00 or even 000 that should be small enough for convenience, and with bristles so fine that they are incapable of damaging the hairspring.  Get a good one though, like Windsor-Newton or similar.  I have never had a Windsor-Newton brush shed on my art or other work.  You want a soft brush that will not shed.
    • Sounds interesting but how do you push the button if you’re holding both ends? the large current draw overheats after 3-5 seconds and the thermister triggers. A great tool for magnetizing things but I’ve not be able to ever demag anything with it because the emf is so strong it pulls the item off center (down or up).   I paid $89 bucks for it from  CAS-KER, if someone on the board wants it I’d gladly sell it for $25 plus shipping (probably US only otherwise postal costs are prohibitive). Just sent me a note offline.
    • Hi. First thing to do is measure your oil movement as the vx32E and the 43 look very similar but one is a couple of mill smaller the vx32E.  Also the canon pinion heights differ attached tech sheets for 7N22. And  VX43, check details on the sheets. 7N22A_29A_33A_42A_43A.pdf VX43.pdf Hattori VX32E - Specification.pdf Hattori VX32E - Disassemble.pdf
