Watch only works upside down
Hello, today I picked up an old, not working watch that i have had lying in a drawer a long time. It did not tick at all and I am quite sure the main problem was that the pallet fork was stuck in its jewel sitting and could not move at all.
I cleaned and re oiled the movement and not it only works when I lay it upside down, or at least it does not work with the right side up. It ticks a few seconds but then stops.
Any tips on what could be the problem? I know that there are about a hundred different possible problems but since it works fine upside down and not at all otherwise I figured someone might have had the same problem. (It seems to be worse during a specifik time of each minute, but not just at one point but rather during a 15 sec period of each minute).
Thankful for any answers, Jakob
That would be my first guess as well, something amiss with the balance staff.with the watch dial down gravity would tend to pull it down so the impulse jewel would engage the pallet.With the watch dial up its sounds it might not be.
.. all of the above, and check for foreign bodies obstructions that may have been introduced while cleaning.
I had a small hair mysteriously appear in one watch that I was working on, which caused a similar issue. Worst of all, the watch worked reasonably well till I cleaned it.
The hair was nicely attached to the top plate and dangled down when the watch was face up, obstructing the palette fork, but moved nicely out of the way when the watch was face down. The hair looked suspiciously like one of mine, but I didn't do a full DNA test. :unsure:
  • 5 years later...
Same thing happened to me. Cleaned and oiled a movement and would only work upside down. I noticed a couple of the coils on the balance spring were stuck together (from my poor oiling) so I re-cleaned and it worked fine.
    • This is not rare at all, the dial code and case code don't usually match.
    • Good question!! Anyone know of a substitute movement??!! 🤔🙏
    • Interesting issue that I just noticed: this Seiko 5actus Watch from 1977 has a calibre listing on the dial of 7019-8030R but on the case back it says 7019-8010!! Like a mis-printed coin, is this watch therefore worth a lot of money for its rarity?? 🤪😲🤔🤪
    • I wish that was the case. The Aegler movements used in the early days by Wilsdorf & Davis (for brands like Rolex and Rolco) came in several sizes and without designated calibre numbers that survive.  They become a bit easier to identify during the 1920s. Below is an Aegler-Rebberg, 25.74mm in diameter. It’s from a woman’s Rolex wristwatch. Stamped Rebberg and 500 on the dial plate (but it isn’t a Rebberg 500, it’s the wrong size).  I’d be interested if anyone can identify the movement.  It is based off the Aegler Nr.1, circa 1903, but they based many many calibres of different sizes on it. The closest I have to a positive ID is the  ‘Rolex Nr.50’ circa 1917, but no dial side images or movement sizes are available in the references. There are identical looking movements in many sizes.  The 25.74mm of this movement is a particularly strange size for the era, it equates to 11.41 lignes.      Best Regards, Mark
    • It looks like this movement comes with a number of different shock settings. Emmywatch shows that it comes in versions with no shock settings, 'Incabloc', 'shock resist', and 'Supershock'. Perhaps the different settings position the impulse jewel/roller table in a non-ideal position relative to the pallet fork/guard pin. Are you able to check under high magnification if the pallet fork and roller table are able to operate without any interference? Just for fun I took a look and I have one FHF 70 in my collection, a West End Secundus with a non-shock protected FHF70. I had a note with the watch that said, "Movement is stamped 'FHF 70', but the FHF70 looks to have sub-seconds instead of center seconds movement (??)" but that a google search turned up both types for this movement. EDIT: I just took a look in my parts drawer and I have a few of these movements, both in center seconds and sweep seconds, but they all are non-shock protected.
