Intro and questions
SybrenAmne
Hello fellow WIS-persons.
I like to introduce myself on this forum. My name is Sybren, living in the Netherlands,  Europe.
Just purchased an Elgin 761, in very nice condition, with a very nice history, being the first US-made perpetual automatic.
I also have a Bulova 23 b, 1956, also the first US-made perpetual automatic, little bit younger than the 761, but, question 1, according to some, designed in Switzerland, and 'only' US manufactered and assembled. Is this correct. I cannot find info about this.
And than, I really like to date the 761. On the case are stamped 6852 and T886877. Question 2, Is there a way to date this watch? Should be manufactured between 1958 and 1961, but I like to narrow this down.
Btw, I also have a 607 bumper incoming, to complete this mini-collection...
My first watch is an new bought 1984 Scubapro quartz diver, similair to some Heuer, Sinn, Bell&Ross and Dugena models from that periode. Unknown is where this Scubapro is manufactered....
I also have some, vintage, Seiko's, a 1968 Skyliner and a Tanaka-case King Quartz, both real beauties...
so, slowly transformating from single watch guy, quartz minded, to vintage mechanical watch collector...
I hope some one has info about the Elgin, for me this is a really interesting part in horological history. I want to learn.
As for repairs, I don't have the tools ore the skills... but maybe one day, who knows...
Sybren
welcome Sybren,
for your Elgin Thin-Thin, you can refer to this presentation we put together to attempt to identify them
https://docs.google.com/presentation/d/1d15PHf44V9OaRG_TabSqscd8G3QA7AvQ6sITeQdEm_I/pub?start=true&loop=false&delayms=9000
Elgin had ceased tracking movement production with serial numbers, so the best you can do would be from November 1959 as the earliest date when the Thin-Thin's were first launched as the Thinline and they were renamed Thin-Thin shortly after that.
Thank you, friendly forum WIS !
From the presentation I've learned my 27 must be a 1961 model P.
This is really nice, and what vintage watch-collecting is all about. First you have a question, you research, you Google, like walking in the dark, and suddenly , Beng! A dive in a pool of wishdom. Really nice.
This brought me to a small conclusion about horology in general and especially vintage: 'The cookie-jar is never empty!' ....there is always another, nicer model, waiting for you.. for example the 27-b in the presentation. Wauw!
Thanks again, Sybren
    • Post some pictures , some good close ones of the parts you've described.
    • Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. If its a potential problem for amateurs to use then i would prefer not to take the risk .
    • Following on from my question about identifying screws in the AS2063 movement that basically fell out of the case in bits, I’m pleased to report that I’ve got it all back together, and the movement is running pretty well.    But… There’s something wrong with the keyless works and hand setting. It’s fine in winding and quickset date position - these work - but in hand setting position winding the crown turns the whole gear train.  I don’t really understand how it’s meant to work. It doesn’t have a traditional friction fit cannon pinion.  The second wheel is unusual with a pair of smaller pinions on it, which seem to interact with the barrel and the motion works.    Could this be the problem? I must admit I just cleaned it and popped it in place when reassembling the gear train. I’ve lubricated the pivots but didn’t do anything to the extra bits on the second wheel.    Does this make sense and is anyone able to figure out what I’m doing wrong? Thanks in advance, as always.    ETA - the parts list calls it the Great Wheel, not second wheel.
    • You're thinking metal to jewel in general I guess. Maybe it would be a good idea to peg the pallet staff jewel hole on the main plate after the epilame treatment. I think that could work as it is my impression that the epilame doesn't sit very hard, but I could be wrong about that so feel free to educate me. I didn't remember that 9501 was thixotropic (thanks for the link). That would mean it's even runnier during impact (lower viscosity) so perhaps it's time I get some fresh grease as mine seems a bit too runny. What I have seen is a whitish surface after washing but it goes away if I scrub the surface with a brush in a degreaser (Horosolv). I don't think it embeds itself in the metal but sticks very hard to the metal. I don't worry too much about the cleaning solution. I just want perfectly clean parts and my solution can be replaced for little money (ELMA RED 1:9). Anyway, I quite often need "to strip back and rebuild" and scrubbing parts by hand isn't exactly the most stimulating part of a service. Just got confirmation that Moebius 9501 has a lower viscosity (68 cSt at 20° C) than 9504 (305 cSt at 20°). The viscosity of Molykote DX is 285-315 cSt at -25° to +125° C. I was surprised to see that the viscosity of Moebius 9010 (thin oil!) is higher (150 cSt at 20°) than my 9501 grease!
    • I’ve had a couple movements where it is clear the previous watchmaker was diligent with lubrication but the old epilam had turned to a fine white powder covering the pallet fork and keyless parts, which can’t be good for parts. I’m spare with epi since I don’t know how long it takes to degrade to that state…
