It's been a while since I've worked on a movement as old as this. A friend asked me to look at whether I could get his great-grandmother's watch working again. When I first saw it, I thought it was an old 1920's ladies wristwatch, though thought it odd that the winding stem is at 12. However, on closer examination, it resembles more of an old pocket watch movement. Now amazingly, the watch is ticking when wound but I cannot pull the stem to set the hands. On removing the dial, I can see the yoke and yoke spring on the opposite side. But would I be right in thinking that it is missing the setting lever? There is a space that looks suspiciously like there could have been a setting lever there once but I could be wrong.
I'd also be interested to hear your opinions on the age of the movement. I'm thinking around 1900.
What's more surprising is that when the case is closed, you don't see the chipped porcelain around the edges, so thick is the bevel. It looks so nice and ornate and when the case is closed. Would love to be able repair but have my doubts.
Any ideas about the keyless works?
Thanks in advance.
Thanks in advance.
What happens when you turn the keyless and observe the works on the face side?
nickelsilver is correct, you push the little pin in next to the button. That movement is a cylinder. You must let the power off before you remove the balance. Cylinder movements do not have pallets. If it is a gold case you can date it by the hallmarks.
Did not see that
Sent from my GT-N5110 using Tapatalk
Thanks for your interest. Anti-clockwise, the sliding and winding pinion rotate and the yoke rises and falls as the sliding pinion turns. Clockwise, the winding pinion only rotates and begins winding the mainspring.
15 hours ago, nickelsilver said:
You have to press in the pin just next to the crown to set. This is a transition wstch between key and stem setting.
Perfect. Thank you, you have solved my mystery. Surprisingly, I've worked on a few pocket watches in the past but never come across one like this.
@oldhippy Thanks for your confirmation. The outer case appears to be gold and has 14K stamped on it with what looks like a squirrel logo underneath (again not seen this before) but unfortunately no hallmark letter to identify the year. On the inner dust cover, it has CUIVRE stamped on it (french for copper). So this really is quite an unusual watch. I've worked on cylinder movements on pocket watches before so thankfully understand some of its peculiarities. I'm going to hazard a guess that the watch is from around 1900.
Thanks in advance.
Hi it’s what you call pin set movement if you need spare parts they use these movements in trench watches if you need a glass I will probably have one.
  • 9 months later...
The squirrel is the Swiss hallmark for 585 gold.
  • Similar Content
    • Welcome to the forum. You're best starting with something that you know runs well and keeps good time. That way when you've stripped and service it, any problems are due to something you've done.
    • Sorry to say it, but you’re very likely to break or lose something when servicing a wristwatch for the first time — I’ve been there! So, if these watches have any value to you, don’t attempt to service them as a beginner.
    • In writing "shimming the staff" I was alluding to the idea trailed in the above referenced thread of inserting a hair along the staff which, as the discussion there covered,  could result in some eccentricity. By making a (more or less) complete cylinder I was hoping to avoid that problem. Don't tell anyone, but needing a very ductile metal to do this by manipulation at such a small scale, I used a piece of an empty Tomato pureé tube! It occurred to me that the material's ductility(?) would also put less stress on the RT in forming a sufficiently tight seal. Anyway, that's how I avoided the temptation to use glue. No doubt your punctuational response to this confession will be "!!!" !
    • Hi All. I would appreciate some advice for a complete newbie on getting into watch servicing - nothing serious,  just as a fun project. I've got a thing for hand-wound watches and would like to bring an old watch (or two) back to life, so looking to learn to do a strip-clean-oil-assemble cycle.   I've toyed with this idea in the past (years ago) and picked up a couple candidates to learn on, but never found the time for them.  One is an old Ingersoll, swiss-made 17 jewels. It seems to wind and tick. Casing, dial, glass are in great shape, so looks like a good candidate to me for the first service. The other is a Benrus DR23. It winds and makes a few reluctant ticks, but then seems to stop. Casing looks like a complete gonner, and the dial is in pretty poor shape too. If the movement is not broken and just needs a service, I wonder if there's any possibility of getting a cheapo Chinese casing & dial to fit this movement in, or is it extremely unlikely to be the right size?   For a start, I want to strip & assemble a movement, perhaps a dozen times to build up the basic parts handling skills. I see that online advice is to buy a Chinese-made ST36 for this purpose. Can I just go at the Benrus or Ingersoll instead, or does it make more sense to get a cheap ST for this? Thank you.
    • Hi,  I have this vintage Navitimer 806 with a bezel that plays a little bit as shown in this video: https://imgur.com/a/2NjdiF0 How would you fix this? I don't see where a gasket would fit for instance. Also, it seems this issue happens sometimes with older Navitimers.  Thanks
