Fitting A New Watch Stem.
Geo
When fitting new stems to watches I use these tools :-
Digital calipers,
Fine grade diamond lap
Wire cutter
Pin vice
Now for fitting.
(1) Hold the stem in the pin vice and screw on the crown tightly by hand.
(2) With the movement fitted correctly in the case, insert the stem until it locks in place. Now measure the gap between the case and the underside of the stem. In this case it is 2.16mm.
(3) Subtract 0.2mm from this size and this will give the amount to remove from the stem. In this case it will be 1.96mm which will give 0.2mm clearance below the crown when fitted to the watch.
(4) Now remove the crown from the stem and hold the stem very tightly in the pin vice, then place the pin vice and stem between the jaws of the digital calipers then zero the calipers.
(5) Remove the calipers and without touching the zero button set them to minus 1.96mm. THEN RE-ZERO THE CALIPERS AT THIS LENGTH The wire cutters are now used cut off the excess thread leaving a small amount to be filed to the exact length.
(6) All that is required now is to dress the stem with the diamond lap a little at a time until the calipers read zero.
(7) Finally screw the crown on tightly and it should be ready to fit to the watch without further adjustment.
I find that this method cuts down on trial and error.
FOR SCREW DOWN CROWNS.
A) Screw down the crown tightly onto the case without the stem and measure the distance nbetween the bottom of the crown and the case.
B ) Screw the new stem tightly into the crown, then insert into the watch until it engages and locks into the movement.
C) Press the crown down firmly as far as it will go and hold it there.
D) Using the vernier callipers, measure the distance between the bottom of the crown and the case.
E) Subtract the size determined in (D) from the size measured in (A) then subtract a further 0.15mm from this size. This is the amount to shorten the stem by. This should allow the crown to screw full home without compressing the stem too tightly between the movement and the inside of the crown.
F) Cut the stem leaving it slightly longer than the size determined in (E), and dress down to size using the diamond lap and vernier callipers as described in the original post.
G) Screw the crown onto the shortened stem and check fit and function, before using a tiny spot of Loctite 221 to secure.
Click here to view the article
  • Like 17
OOPS, I forgot to say the calipers had to be re-zeroed again!
Please edit this into the original post if possible Mark.
Thank you Geo..For my part I purchased the same type of stem and I measure the same length and I cut and I file the end of the threads of the stem. for me, this solve the problem..I'm lucky because it has never happened to have a watch with a piece of the stem. It is also rare that I buy a watch with a broken stem..Sorry for my bad english ;) your explanations are the best..
Your wish is my command :)
  • 2 months later...
  • 4 weeks later...
(A) Screw down the crown tightly onto the case without the stem and measure the distance between the bottom of the crown and the case.
(B ) Screw the new stem tightly into the crown, then insert into the watch until it engages and locks into the movement.
(C ) Press the crown down firmly as far as it will go and hold it there.
(D) Using the vernier callipers, measure the distance between the bottom of the crown and the case.
(E) Subtract the size determined in (D) from the size measured in (A) then subtract a further 0.15mm from this size. This is the amount to shorten the stem by. This should allow the crown to screw full home without compressing the stem too tightly between the movement and the inside of the crown.
(F) Cut the stem leaving it slightly longer than the size determined in (E), and dress down to size using the diamond lap and vernier callipers as described in the original post.
(G) Screw the crown onto the shortened stem and check fit and function, before using a tiny spot of Loctite to secure.
This is now added to original post by Geo.
Edited by Geo
  • 10 months later...
Hi Sendikumar,
The screw down crown has a spring between the stem and the crown (it is part of the crown ensemble) that creates a certain tension when properly screwed into the case tube. The spring tension translates into a shorter stem -- since the spring supplies the rest of the length -- and in the end it "takes back" that length to seal the watch...this is normally used in diving watches. Did I confuse you more? I'm not very good at explaining!
Cheers,
Bob
    • 1973 Bulova Diamond Excellency Q. 11 AN mov't manual wind. Love the UFO look of this one. Not sure the size of the diamond but looking around for an advertisement to see if it is.listed....strap is not original but the buckle is signed along with the crown. In excellent condition.
    • Just missed it! I have a donor movement on its way. But thank you for the offer--I'll let you know if I need anything else.
    • My latest. Timex 2465. Replaced the crystal, caseback gasket and spring bars. All in less than $5US. Added a gray NATO strap I already had in stock.
    • I have some Gruen 510's in my donor pile if you need parts.
    • I've been intrigued by everyone's input here...so I decided to give this a shot. I bought the"typical" Pearl watch-machine basket and trays, for about $65. The trays are good,..the housing is a nightmare ! Thought it would take the mixer off my bench at anything above about 200rpm. The housing is cast of course,..and it's not "true" at all...so the harmonic vibration was insane. So,..I bit the bullet and bought the Elma housing and top. Not the baskets though, as the Pearl one's fit the Elma. Saved a bunch there. The basket and lid came to about $80 with shipping. The opening in the Elma top is 8mm, and the shaft that came with my stirrer is 6mm. I bought a piece of steel tube, 8mm O.D., and 6mm I.D. Cut off about an inch of the tube, and drove the rod into it. Gives a really snug fit.... Lightly champfered the leading edge of the 8mm section, then lightly tapped it into the top of the Elma lid. Spins like a dream now So... I have about $240 total into this including jars and steel mesh for the wave breakers   I'm pretty happy Best to you all   Randy
