How Do I Remove Movement From 6309-523A Please?
Oldhippy - I see you’ve used all approaches then. I too have a screw down press and a lever press here, but I’ve had more practice using the screw down. I wonder, though, whether I might be able to be a little more controlled and gentle with the lever style press? Not sure, I guess I’ll find out, but not until the moment of truth, when the die and the crystal meet under pressure, just a few millimetres from the dial and hands. Yikes. This is an adventure 🙂
It might be soldered in, try applying heat. -
I had two different tension ring tools one was screw down the other was press I liked the press better. Just to let you know how well my workshop was equipped I even had the Omega glass fitting tool and the Tissot.
Lol, i remember watching that for the first time and thinking Indiana there is no way that small bag of sand weighs the same as the gold statue 😅
