rotary
This has been discussed in great detail several times already. All of the methods you mention carry some level of risk. If you search for @praezis posts on the subject, you can find convincing arguments why cutting off the hub (not the rivet) is the safest method.
I'd thought the same along with the fact that they'd already stated the train ran without the balance?
🤔 how might a loose cannon pinion explain why the movement wouldn't tick with the balance in place or the lack of fork/escape wheel interaction ?
