Showing content with the highest reputation on 10/03/16 in all areas
  1. Check Ebay 252518388567. Message the seller to get the board alone.
  2. OK, so me and Mrs H did Christmas day with the family, and then we did Boxing day with the family, and then we were granted a day off so got to relax, and for me that meant I had the chance to tackle a little project that I had acquired as part of a job lot from a long retired watchmaker that had been sitting around in a shed for about 35 years (the job lot, not the watchmaker). Pocket watches are not usually my thing although I do own and use a couple. Orphaned pocket watch movements are even less my thing; but this little baby was in such a state that I couldn't resist the challenge. I don't think I have ever attempted to resurrect anything in quite such a sorry state as this before but it wasn't all bad. The balance was free and with sufficiently little end shake to hint that the pivots were not broken. However, the accumulation of dirt and dried grease obscured just about everything else. The inner coils of the hair spring also looked to be completely filled in with rust/gunk. With the balance cock and balance removed things got a little more interesting. Underneath the grime is a rather nice English Lever escapement with cap jewels on both the pallet and escape wheel pivots. A good sign, but I need to let down any power in the mainspring before I go any further, which means flipping it over and removing the dial as the keyless works are dial side. Not quite so bad under here as the dial has kept the worst of the dirt away. You can see too that both ends of the pallet and escape wheel pivots are capped, and the click spring is a proper cut steel affair, not wire. There is worrying evidence of rust on the steel work though. With the power let down the pallet and escape wheel cock is removed and you can now see the English Lever escapement in all its (rather grubby) glory. What a mess, but through the gunge there are just little hints of quality watchmaking peeping through; the thickness of the 3/4 top plate, and the cut and form of the teeth on the wheels. The top plate comes off taking the entire train and barrel with it as the pivots are seized in their bearings. The main plate is a mess. The under side of the top plate with the train still in place. The barrel has vacated its bearing revealing rust. Not a good sign but it could be worse. The train now removed from the top plate and dropped back into the main plate for a reference shot. The set lever and stem retaining bridge do not look healthy. Again though the set lever spring is cut steel, not wire. Oh yuk!!! The main plate now stripped. The barrel lid, with another nice touch; Geneva stop work, designed to only allow the central portion of the springs torque curve to be utilised thus reducing isochronism. Main plate, top plate, and escapement cock ready for cleaning. Ok, so whilst I was stripping all of this down, the hair spring, removed from the balance has been sitting in some Cola. The result is that the rust has softened and with a little careful tweezer work with a pair of Dumont #5's, most of it has been dislodged. The terminal curve of the Breguet over coil is badly out of shape due to a mishap when trying to unpin it from the rusted steel stud. I'll sort that out later. For now it's back into the pop to see if I can get those coils a little cleaner. Everything cleaned and ready for reassembly. I have a couple of spare jars for my cleaning machine and when I renew the cleaning solutions, the old stuff is kept in the spare jars. Any really heavily soiled movements get a "pre-wash" in the old chemistry so as to prolong the life of the new. With this watch everything was washed in the old gear and then very carefully gone over with peg wood, a G/F scratch brush, and tooth paste on a cotton bud in order to remove all of the staining that the bath didn't touch. All the jewels, bearings, and pinion leaves were also pegged out. Then it all went for another cycle through the old stuff before going through a normal cycle through the fresh chemistry. Main plate dial side prior to reassembly. And train side. Scrubbed up quite well I think. Stem, winding pinion, clutch, and stem retaining bridge reinstalled. Set lever and spring back in place. I haven't removed all of the rust pitting from the stem bridge and the set lever as it was too deep and to take it out would alter the shape too much, but it has been stabilised. The reassembled barrel and Geneva Stop work. I have reused the old main spring for now but made a note of its dimensions in case I choose to replace it. Another (gratuitous) shot of the Stop work as I just love it :-) Barrel and train back in place and things are starting to look fairly healthy. The top plate goes on. Quite a difference compared to the strip down shot from the same angle. The keyless works back in place dial side. And the balance, with reshaped and re-pinned hair spring goes back into place. After about half a dozen attempts to adjust the beat, removing the balance from the cock and turning the hair spring collet each time, and she comes to life!! Everything back in place dial side. And the cleaned up dial goes back on, complete with (broken) hands. And if you ignore the rate error for now (I need to re-pin the hair spring a little shorter), it's actually not a bad performance. As I said at the outset this was a challenge for challenge sake. I really enjoyed doing it and have learned a little bit about quality English watchmaking from the days when we were really rather good at it. I have absolutely no idea what to do with it now though although I want to try and find a bit more about it. Here is what I know; The name on the dial is T Donkin. There was a T Donkin watchmaker in Scarborough but I have no dates (yet) I'm guessing somewhere between about 1890 and 1910. It is a 19 ligne, 19 jewel English Lever escapement movement with capped balance, pallet, and escape wheel pivots (diamond on at least the balance top pivot). It has a screwed, split bi-metalic compensating balance, Breguet over coil hair spring, and Geneva Stop work on the barrel, and a 16200 train. A technical spec that suggests that it was of a reasonably high grade for its day. I still have a couple of issues to address though, the most problematic of which is that it has a slightly bent balance staff pivot. I decided not to tackle this on this occasion as the risk of breaking it whilst trying to straighten it was too great and I desperately wanted to see it running, but I may have a go in the future. I will re-pin the hair spring at the same time to get the rate up to where I can regulate it properly; it is currently about 25 minutes a day slow which is way beyond the range of the regulator. I also need to re-attach one of the dial feet and source some new hands. Then of course there is the question of recasing it. If you have made it this far then thank you for indulging me :-) I hope you have enjoyed it. If anyone can shed any more light on this little old lady I would be very grateful.
  3. You will find it hard to undertake watch repairs with cold hands. In the winter my workshop was like an oven I like heat.
  4. At this point, you might want to try soaking the movement in Naphta (Zippo or Ronsonol lighter fluid). Naphta is a more aggressive solvent than iso alcool. I did this recently on a 2002 Rotary quartz watch movement with success. Of course, results may vary depending on the extent of the corrosion, if the corrosion reaches the quartz oscillator (that's number 5 in the picture, the round tube), then the movement is toast because that's the main component of the watch. I have a friend who's an electrical engineer explain this to me before I attempted it. http://www.explainthatstuff.com/quartzclockwatch.html Now about the naphta. There are two ways of trying this. You will need to remove the movement from the case. 1) Drip: Get a small shallow glass dish. Place the movement in a vertical position so the naphta will flow into the dish. Be gentle, a little goes a long way the point of the exercise is just to flush the acid corrosion out. Gently squeeze the bottle or can to let it drip in the battery cavity area. Carefully remove the movement and place it on a paper towel or thick napkin to allow the naphta to drain, do not try to air dry or blow on it to accelerate the drying otherwise it will fly all over. Wait at least 10 minutes, and then gently shake to see if any naphta remained in a cavity, it should drain out. If there was naphta, again wait a few minutes it will evaporate. 2) Immersion: Get a small shallow glass dish. Place a little bit of naphta in the bottom of the dish, just enough to cover 2 mm at most (the upper part of the battery cavity). Then carefully place the movement battery cavity side down into the dish. Very gently, agitate the dish from side to side to distribute the naphta. Let sit for a minute or two, not too long the quartz occillator tube is sealed it should be alright if the corrosion hasn't reached the tube. You will see some sediment at the bottom of the dish, that is the gunk inside your movement. Again, carefully remove the movement and place it on a paper towel or thick napkin to allow the naphta to drain, do not try to air dry or blow on it to accelerate the drying otherwise it will fly all over. Wait at least 10 minutes, and then gently shake to see if any naphta remained in a cavity, it should drain out. If there was any naphta, again wait a few minutes it will evaporate. If you are concerned about attempting this, there are other great ideas on this site (they consider the different types of cell batteries): http://great-british-watch.co.uk/how-to-spot-and-deal-with-watch-battery-leaks/ Hope that helps.
  5. Renata, Rayovac, Varta or unbranded, a broad bet, but the one I place. You're right about Sony and Energizer, Parmenion, they never leak unless left in watches years after draining, and even then it's usually very slight.
  6. I will heed those words of wisdom (Loctite 222), thanks !
  7. Padi Turtle finally arrived. Yup it's a big watch. I'm migrating towards smaller vintage watches but I just had to get this one. Very weighty. I'm very impressed with the standard bracelet with solid end links and the little diver's extension but I had to remove 5 links to get it on my 6.5" wrist.
  8. That is because the item was shipped 1st class international, which is not trackable. As mentioned above, USPS trackable shipping (priority intl) starts at three times as much.The weight of 68 gr. is perfectly appropriate for a watch movement in a padded envelope. Depending on the country, provenience and other factors, there is no invasive scanning of small packets, often more frequent is the use of sniffer dogs for drugs. However it is always possible that packages are inspected and value re-assessed by customs.
  9. I didn't see anything that would prevent someone from outside Canada in using it.
  10. Just for the record, I have updated my c/c account with the correct address and the payment was accepted.
  11. JK, I think it was probably about 4.5 to 5 hours of actual bench time. It's difficult to be certain because of the amount of time spent taking pictures, making notes, and waiting for the cleaning machine (half an hour in the wash, 10 mins in the first rinse, 5 mins in the second rinse, and 5 mins in the drier), but if I work it out and take out the camera time it took about 45 minutes to strip down and assess each part, 45 minutes to reassemble checking end and side shakes on all the wheels, lubricating and checking that everything ran smoothly. Cleaning and reshaping the hair spring took about 45 minutes as well, and half an hour to adjust the beat error. Then in between all that probably 2 to 2.5 hours of cleaning, polishing, buffing, stain removal, and pegging out. I just remembered, I did have to make a new taper pin for pinning the hair spring, and that took me about another half an hour.
