Waltham PW Mainspring Disassemble
MrBeat
Happy New Year All :)
Well its a good start to the year and ive already come unstuck.
I don't usually work on American watches but i have a Waltham that requires a new mainspring and ordinarily this is a non issue but i can not see how the barrel comes apart to change it as it seems stuck in place ? Does the barrel arbour get punched out ? I can not for the life of me see how to get this out it seem intent on staying in ?
Any help with pointing out my obvious error will be most appreciated, Photos Below >
It appears theres play but the thing does not want to come apart, am i missing a secret here ?
Well the penny dropped :D
Turns out the arbour is a two piece that screws together, although this one had ceased and just needed an extra umppfff to get her to release. Apparently this is a common assembly on Walthams of 19 Jewels ( this case a Cresent Street ), a small and old picture on the interwebs from Waltham shows the assembly which is why it had me baffled for a moment.
Now the parts are cleaning before new spring is fitted, problem solved :)
  • 4 months later...
@MrBeat @oldhippy I'm in the middle of replacing am mainspring on a Waltham 12s and I'm having similar trouble.  I thought maybe the plate held the assembly together, but it's near impossible to install without the mainspring lifting the cover slightly off the barrel, unseating the pivot.  I had no trouble getting the arbor out though, this one appears to feed through the assembly, but there is no means to keep everything captured prior to installation.  Really stumped here.
    • You could also use a very fine artist's brush to brush between the coils.  If you get a size 00 or even 000 that should be small enough for convenience, and with bristles so fine that they are incapable of damaging the hairspring.  Get a good one though, like Windsor-Newton or similar.  I have never had a Windsor-Newton brush shed on my art or other work.  You want a soft brush that will not shed.
    • Sounds interesting but how do you push the button if you’re holding both ends? the large current draw overheats after 3-5 seconds and the thermister triggers. A great tool for magnetizing things but I’ve not be able to ever demag anything with it because the emf is so strong it pulls the item off center (down or up).   I paid $89 bucks for it from  CAS-KER, if someone on the board wants it I’d gladly sell it for $25 plus shipping (probably US only otherwise postal costs are prohibitive). Just sent me a note offline.
    • Hi. First thing to do is measure your oil movement as the vx32E and the 43 look very similar but one is a couple of mill smaller the vx32E.  Also the canon pinion heights differ attached tech sheets for 7N22. And  VX43, check details on the sheets. 7N22A_29A_33A_42A_43A.pdf VX43.pdf Hattori VX32E - Specification.pdf Hattori VX32E - Disassemble.pdf
    • I was spitting out flowers and leaves for 10 minutes,  fortunately 3  people saw it and promptly whipped out their phones to film the quick " nothing to see here " recovery  🤣🤣
