Looks to be some while searching from the UK . Item 113231855758 looks the have date at 3 which may be what you're looking for.
I've no connection to this seller and there others returned when I searched for EB8800 which might be better options for you.
Hope that this helps.
Sent from my moto g(6) play using Tapatalk
  • 6 months later...
  • Similar Content
    • A helpful way in aid of assembly is to place all the wheels in their respective places, place to plate on the top and fit a couple of the nuts onto the pillars. This stops all the wheels wobbling about as they are lightly held by the plate, you can manoeuvre the pivots into their holes, using a tool , usually home made or can be bought on eBay. I made my own. As the pivots align and fall into place screw the nuts down a bit to keep up the tension on the plate untill all wheels are in place then tighten down sufficiently to keep the plate in place whilst checking the end shake on ALL wheels and their location when all is good only then tighten down the plate.
    • I'd say my Pultra 10 lathe. It is just so well made and everything fits so tightly together.
