I posted in an earlier post the problems I was having getting a retaining clip for the Rotor. However this problem is bigger than I first thought. This watch was supposedly serviced  by a very reputable Swiss watch company who charged £475. this was over 2 years ago. It ran for a few weeks after but then stopped. Why he did not take it back is another story.
Anyway onto my tale of woe. When I opened the watch case this is what I found. In my opinion this watch has not been cleaned. When I removed the reversing wheels they were filthy.
691486942_Firsstinspectionafteropeningwatch.thumb.jpg.8c02188a19d653590883b95c01611cef.jpg
I have not been able to find a replacement bridge so I have secured the old jewel with loctite. However this is not good because it should be secured by what looks like a rubbed in jewel method. see below:
My question is does anyone know where i could purchase a new new jewel or a replacement bridge. The customer will have to pay so cost is not an issue.
If the replacement clip works it has a chance but I am not happy.
The movement is cal.  3075
I'm not sure if the bridge of the basic calibre 3035 is interchangable (maybe the only difference is the writing on it?).
https://www.ebay.de/itm/Rolex-3035-5061-Automatic-Device-Bridge-Upper-Spare-Parts/263767064237?hash=item3d69bdfead:g:RzAAAOSwgoxbKOLn
Another possibility is to contact Kevin in New Zealand. He could help me with many 15xx parts in the past, maybe he has the bridge.
https://www.tapatalk.com/groups/vintagerolexforum/viewtopic.php?f=207673&t=235524&p=535888&hilit="movement+parts"#p535888
Here are many lists of spare parts for Rolex calibres:
https://www.r-l-x.de/forum/showthread.php/88631-Werk-Ersatzteillisten
In the 3035 list there are the parts 95063 and 95063-1. I think one of them is the one you need if you want to replace the jewel and they're available on ebay.
Erik
Erik
Thanks Erik, The bridge for the 3035 certainly looks the same. I tried to register with the website you have given but it was not successful. If my repair does not work then this could be an option. The cousins catalogue picture shown (pp198) is correct BUT the clips supplied are a completely different style. So I still have not got the correct clip. I have put in a bid on eBay for one I found in France. I have some small c clips that are too thick and they might work but again I have my doubts.
What fun !!!!
If you have the tools I suppose you could widen the jewel hole,  turn a chaton for the jewel, and press fit the assembly.  The measurements would have to be spot on though and I'm not certain you could press in a jewel that was originally designed to be rubbed in.  Perhaps they have a different outside geometry than a typical friction fit stone.
Another thing to consider is how much stress the oscillating weight would put on this fix.  Perhaps that's why Rolex used a rubbed in jewel as opposed to a press fit?
You might be correct but if it don,t work one ruined Rolex. My method of securing it with loctite if it don’t work nothing is broken
In my opinion, this is a big Achilles heel of the Rolex movement. Otherwise it's a farm tractor and will run no matter what.
The jeweled rotor is quiet, but problematic.
I suspect you have a worn axle on the rotor as well. Jewel and axle should both be changed together. If the jewel hole is oversize, you could TRY locktite bearing set (slightly different than threadlocker) if the fit is "close enough". If it's really sloppy, you could try the ghetto solution of rebuilding the bore with epoxy and then reaming to the correct diameter. But there's a lot of load on the jewel so it might totally fail (something to try AFTER you find a replacement bridge)
Now for the bad news: I had this done by a Rolex authorized dealer/shop for my 5512 and the rotor still rubs.
If at all possible, I suggest finding the local authorized dealer, and see if they can order the complete winding bridge for that caliber. Parts will be a) expensive and b) on an exchange basis. I have seen earlier bridges available on ebay but honestly haven't been looking for this caliber. Other bridges from the family will fit; however for a Rolex in particular, it would be best to get the correctly marked bridge since they are available.
Another option is www.rolexforums.com where they have sellers from around the world with parts. Prices tend to be competitive to the open retail market. You may have to register to purchase...
If at all possible, I suggest finding the local authorized dealer, and see if they can order the complete winding bridge for that caliber. Parts will be a) expensive and B) on an exchange basis. I have seen earlier bridges available on ebay but honestly haven't been looking for this caliber. Other bridges from the family will fit; however for a Rolex in particular, it would be best to get the correctly marked bridge since they are available.
Thanks I have inspected the axle as I know this is a known fault with Rolex. However it is in good condition. Probably a new/good quality used bridge will be required. That will be the decision the customer will have to make.
Just an update. The repair I did with the jewel seems to have worked. It had been on test since Saturday morning and was taken off Tuesday morning. The jewel is still holding great. I have returned it to the customer giving the customer my reservations. If the jewel does fail I now have a spare bridge. The clip that was  missing I purchased from cousins although a few thou under the original spec it is working fine.
WHAT FUN !!!
ON TEST
WHAT FUN !!!
ON TEST
Hello,
I’ve just posted about my Rolex Daytona Cosmograph 11650, are you able to assist? Are you in the UK?
Thank you.
18 hours ago, messinapete said:
Hello,
Thank you.
Sorry can not find your post.
    • I'm a newb who is a bit late to the party here. I've purchased a Horia movement holder clone. And I'm aware that the support pins for the SW500 chronograph jewels can be different sizes. I purchased 0.8mm pins with the holder. These were all that were available at the time. Will these be the right size? Can someone shed a little light on this for me please?
    • That looks fantastic! I'm obviously a little late to the party here. Can you tell me where you sourced the case that you used in this build?
    • If pivot shoulder almost touches the mainplate, you will see lower amplitude and free oscilation comes to stop quicker. Such touching can stop the watch. This caliber is based on FHF, I think. So some parts of a cheaper movement of same caliber might interchange.  Both observation point to pivot worn short, which support you suspect , "worn pivot".  The problem with pivots wear to this point is , though the watch runs, pivots can easily jump out of jewel holes in the event of shock, pivots are actually not touching the end stones.   Classic watch repair recommends staff replacement or elongating pivots. Non classic let's you flip the end stones to have the dome side of end stone facing the pivot end, this will somewhat or wholly  compensate for the wear.  Regs
    • This watch has a pin end mainspring. It's a blued steel spring and may be the original >100 year old part. As you can see, it is quite set. Can anyone suggest where I might be able to obtain such a spring today? Dimensions: Height: 140 Thickness: 010 Arbor diameter: 340 Barrel diameter 989 (1/100 mm)
    • Many thanks for your answers: 1. I will clean both of them without risk 🙂 2. Both of the rotate inside their setting but they don't seem to come out. I will clean the cock (and the hole jewels) and I will see if they want to go out. I don't intend to force the setting pushing it out by any means. I only hope I don't need the dismantle the whole cock into all its components...! 3. I won't touch it. Only clean. I don't want to take risk... Thanks again! Thanks for your anwer. Yes, I meant short. In fact there are 2 pictures where It can be seen that the balance almost touch the main plate. The balance only spin freely when I loosen the cock screw and also the bottom jewel setting. I cleaned the exterior jewels on the cock and on the main plate. But I can't take the interior settings. I uploaded 1 picture on this  My reply to your comments are below. Apologies as I Replied rather than quote...
