Rolex 8 3/4 Hunter (0528) parts
Hi, any advice on interchangeable parts for a 1948 ladies Rolex Oyster.  The movement has the following markings
Rolex 8 3/4 Hunter 0528  17 Jewels. The Pallet fork and the roller table are both damaged and I don’t have the skills to repair / make replacements. Can anyone advise if other Rolex movements share the same parts which I can substitute as I’m hitting a blank searching on the movement details.
Thanks in advance
Edward4CEBB892-AB3F-4214-A87A-7F47F93E73D0.thumb.jpeg.627a578d18f49a1b0d72c31e4a68e79e.jpeg
Thanks in advance
Edward
Unfortunately Rolex parts are difficult to source. For vintage almost impossible your only hope is troll the net looking for a donor movement.
There may be more clues as to what the movement is by showing a picture of the other side, its a early calibre so is almost certainly produced by Aegler  and with 17 jewels is a Prima  varient these 8 3/4 movements where also the base calibre for the first Rolex Automatics.
Aegler movements where not just supplied to Rolex, Alpina and Gruen also used Aegler supplied movements and some parts for these are inter-changeable.
Quote
Think that the 0528 is a serial number. Check on ebay for donor movement. Seen a  some  Rolex 8 3/4 there. Didn't Rolex borrowed movement from other brands from the beginning ? Like FHF30 is Rolex 59 .
Check Jules borel if they share any parts on other movements. http://cgi.julesborel.com/cgi-bin/matcgi2?ref=ROL_H_8_3/4_L
Edited by rogart63
Search on the answer i got on Jules. Gruen 823 came up. When i search on ebay i found some parts . So think that they at least share some parts like stem and balance.
The movement is a Rolex calibre 510 most parts are common to the 500 series of movement see sheets below for part numbers5b2b393cbdeab_500I.thumb.jpg.b75b005a26f83b80da0e287986fb1fc1.jpg510.thumb.jpg.08c040acd3c80bd0ebe3faebc513b312.jpg
Interchangeable parts with other calibres:
The roller is also used  in Gruen calibres 818, 819, 823, 833, 879, other Rolex calibres 170, 250, 600, 620, 630, 635, 640, 645
    • Looks lint the teeth on the hour wheel aren't meshing with the teeth on the calendar intermediate wheel, maybe the hour wheel is sitting on top of this instead of meshing?
    • If the oil drop was freely standing on an epilame treated cap jewel it could easily slide off if you knocked the watch hard but the balance pivot keeps it in place.
