I think that's a ring holding down the movement. It may be pulled out to disengage and free the movement but you might need to remove the screws mentined before, the 2 on the very edge (maybe at 11 and 5?). The "indentation" on the ring  (12 oclock ?) is to pull it out or so it seems.
Once the ring is removed, the opening will be wide enough for the movement + dial to come out.
Again, I'm speculating here, proceed with caution.
I'm new and know nothing but ill give it a try. Can you remove the winding mechanism then twist the moment with the transistor area up as there looks to be a space their that it may allow it to slide up? Just watched Mark's video with the Rolex movement and turning it seems the same here.
Just a thought !
I'm still convinced that it comes out the front and that the screws will have to be removed to remove the bezel and crystal. I only hope someone who does know tells you before you damage something.
I'm with Geo on this one. It's quite possible that some of the screws are decorative and that others hold down the bezel. Worth a gentle try, perhaps.
 I think Will may have a good  point  did you try all the screws or just a few?
Sincerely,
Jim
I think Will is on the right line. Its either the screws surrounding the bezel or the two screws @ approx 11 o'clock & 5 o'clock that are holding the movement and spacer. If the watch is rusted it might not be obvious that it is ready to come out when these screws & stem are removed & GENTLE tap might show results.
I believe i had one before for repair and if i have good memory,the bezel was pressed in with a gasket.
The screws were only decorational ones
So try the knife way i believe you will succeed
p.s: sent from my s****y phone so sorry for typing mistakes
Where have you been hiding Emso? This is what we have been waiting for!
Besides the job, tapatalk did not inform me that there were new messages in this forum.
So i did not know that someone posted
Br
Emso
P.s can someone tell how can i stop receiving notifications on e-mail as my inbox is full from this forum
p.p.s: sent from my s****y phone so sorry for typing mistakes
I remember when work used to get in the way, thankfully that's in the past now. Great info regarding the bezel, thanks for that!
Edited by Geo
Emso
Hello Emso.  Just had a quick look re emails,  If you click on your name (Top right, near sign in, sign out) amongst the options is my settings and amongst those is notification options to turn email notification On/Off.  Hope this helps.
Edited by autowind
I have looked at this again & again  and I can not see any reason for the screws other than removing the movement. They seem to have a washer or lip and therefore I conclude that they are for holding something, either the movement or a spacer ring.
Ok i will check the longines support, can you tell me the numbers engraved on the caseback?
Found these pics via google that might help. I have added an arrow that shows what is most likely the problem with removal
Edited by clockboy
I agree with Geo & emso. The only info I have found so far is that Boley quote a bezel gasket for this model, this combined with the movement holding screws strongly suggests a front loader.
Emso the numbers on the caseback are 20122247
after looking the longines support and if you see the numbers 950 4842 engraved in the inside of the caseback i can confirm that it is a top loader.
br
emso
Hello all. Back from vacationing at Cape Cod and I have good news. Emso you have a good memory. The movement came throught the front. The screws are only for decoration. See attached pictures. Hopefully I can get it running.post-310-0-04817300-1413654451_thumb.jpgpost-310-0-31710500-1413654473_thumb.jpgpost-310-0-41065000-1413654489_thumb.jpg
Well Done Joe and thanks Emso for revealing the solution. I'm looking forward to seeing the end result.
Hi All,
   Ok I have been looking at this case several times and it just doesn't make sense. Why would you have a top loader and then have to take the back off to remove the stem? Most top loaders are designed so that there is no back to remove. Anyway I see that it was indeed a top loader but would have confused me as well.
Charles K
Edited by CKelly
Hi All,
Charles K
Not uncommon on the various watches I have worked on, both Swiss & Japanese. Mostly due to a large dial on small calibre, but not always so.
    • Well, my fundamental stance is that I want to go in and out without leaving any trace other than a shining, perfectly running movement. So, no scratchings on the inside of the case back lid, no marred screws, no debris, no fingerprints, and so on. That is, my goal is to make it impossible for the FBI to track me down. As a professional, I suppose you might want to keep track of returning watches, but as @JohnR725 mentioned, we can keep detailed computer records without marking the watch at all. That may not be true for every watch, but luxury and COSC-certified movements do have unique numbers. John also says it’s best to leave no sign you were ever there, and I couldn't agree more. Now, suppose the Sea-Dweller I'm working on is one day scrapped, and you want to sell the case-back separately (perhaps the case was destroyed in a plane crash). Then the scribbles on the inside no longer reflect the current movement inside the case. Also, the engraving will likely halve the market value of the case back. It had been "sleeping" for about a week and a half. Yes, the "debris/old lubricant" theory is my hypothesis as well! It will be interesting to see what I find once I have time to start disassembling the movement.
    • I've repaired a few of these, having some success with stripping and cleaning the mechanism.  They are so cheap though, its hardly worth the effort in many cases.
    • Get well soon Old Hippy, torn muscles.,  not good
    • Id love to see how he has the output shaft mounted to this setup, as I have the same rotary stage and stepper in my build.
    • If you see at least one thread protruding, or even a half, then you may have a chance using this "tool", but don't squeeze hard. Lot's of patience, and if you notice any signs of loctite or other adhesives, then apply several drops of acetone on top of broken stem. Use heat (hair dryer) also. You should be able gradually turn it counterclockwise, just like i did on this broken Timex stem, which was glued with something like nail hardener. Then you can use an extender to save your broken stem. https://m.media-amazon.com/images/I/513DVvkfW5L.__AC_SX300_SY300_QL70_ML2_.jpg   You can also try cutting a small grove / slot on top of the broken stem to use 0.7mm flat screwdriver.   Depending on the Crown material and Stem material, you can try dissolving the stem.
