Best current production lathe motor
Titanium
I cannot suggest a particular motor. I have had a look on ebay and there are a few there.
You might want to think about how you are going to control it. I had a foot control and found it very good as I could control what type of speed I needed.
Here's what our lathe expert david wrote about the Sincere (China made) motor:
Their quiet running  induction motor was around $200.00 but I like it much better than the brush type universal motors that are normally used. The  induction motor turns the same RPM whether running free or under a load during a cut. This helps keep a  consistent chip load and reduces pivot breakage during the turning operation.
I have a Multifix, highlights are lots of power, variable speed, and very well balanced.  I ended up with a used one and believe their lofty status is deserved...the disadvantage is expensive and no foot switch which would make it nicer to use.  I believe they are still in production
Many people use sewing machine motors. You can buy these used, or there is a seller on ebay who sells them new and specifically for this purpose for about £50. That’s what I use and im perfectly happy with it.
https://www.ebay.co.uk/itm/WATCHMAKERS-LATHE-120W-CLOCKWISE-ROTATION-MOTOR-CONTROL-PEDAL-Lathe-not-incl/351817207808?hash=item51e9f09000:g:JdIAAOSwGIRXY8FM
30 minutes ago, measuretwice said:
which one, the Multifix?  all I've seen are variable speed
I would say this one. It looks the same and the markings are the same.
I did not know there were different types. I can remember it would take a flexible shaft, but I never bothered.
https://www.youtube.com/watch?v=t34hrkwIRHs
    • Thanks Geotex, From what I can see the keyless works on mine is completely different to those in the photo, I had a bit of a Google and it looks like it's called a rocking bar?? I can't seem to find a single match online though. As far as the setting lever screw goes, you've just explained what I'm doing wrong and why it was probably left out in the first place. It needs to go in before the bridge 🙃. That's why the hole isn't big enough because it's designed to be smaller to stop the screw falling out until the bridge is removed. Thank you for that! I'll remove the bridge tonight and get it refit.
    • The term "digital transistor" is not a term of art--at least in the modern world.  A lifetime ago, there was such a thing as DTL (Diode Transistor Logic).  Resistors were involved, but I am not aware that they were ever integrated into the transistor package.
    • Update: I posted over on NAWCC and it looks like I melted the fine coil wires where they come into the solder lugs. After dropping the heat way down on my iron and being absurdly careful, I have a humming fork!
    • Hell0 @nevenbekriev. Thank you for your advice. I have removed the old setting using my staking set--I will keep the KIF spring, since it is still good.  I am awaiting the replacement setting, and will update when I do that. In the mean time, I looked at the escape wheel and it looks ok. What do you think?
    • Aloha All, I recently bought this Seitz tool on eBay, but it is missing some pushers reamers.  I ended up ordering new parts for those that were missing before I received the actual Seitz tool (bad idea).   Upon inspecting the pushers/bits, I noticed 23 of the 56 provided with the set had no numbers. Further inspection revealed a huge difference in the quality of those unnumbered.  Do all Seitz pushers/bits have a number on them?  I'm pretty sure that 33 of the 56 I received are cheap Chinese knockoffs.  The worst part is that I ordered $80 of parts to replace the missing pushers/bits, and now I'm looking to return the tool. I'm not crazy, right? If these are Seitz parts, they should all be numbered, correct? The first two pictures are the Seitz (numbered), and the other pictures are the suspect parts.  Will I even be able to get a refund?  Thanks, Frank
