Would like to ask how do I remove battery? I cannot figure out how to take it out.
Thanks for any replies.
Just use some tweezers or the tip of a small screwdriver and carefully pry out the battery without damaging the clips/pins/springs that hold it into place.
Some movement's (I can't see if your does because of the poor picture) require that a screw is slightly loosened to move a plate or finger.
There is a springy lever on the right side between the battery and coil. It has a tiny protrusion that goes over the battery on that side to hold the battery in place. Carefully push the lever aside a little and the battery will pop right out. The left side of the battery is held under a shelf of metal. When you put the new one in, place the battery under the shelf and then move that lever aside to let the battery fall into place. Be very careful not to hit that red coil with anything. Many a watch have bit the dust when the coil is hit with a screwdriver that is being used to push that lever aside. Steve
Sent from my iPad using Tapatalk Pro
