Ok, first let me preface by saying I am all for property rights, but when said property isn't in my budget I try what I can. And I'm paying for it now.
It's supposed to be a Miyota 8200 but I'm doubting that. It's def. A franken Citizen and what happened was the stem came loose when I tried to manual wind it. So I tried fixing it. When I went to remove the bottom plate I want sure if it was just the rotor bridge or if it was the plate. Anyway, I unscrewed it and it went flying across the room. I couldn't find a way to reduce the mainspring tension so I thought it was just the rotor bridge... Wrong!
So I think everything is found and it seems correct but I'm unsure. The two brass wheels are the same size and look very similar. I'm not sure if they're in the correct position cuz they flew out too. The problem is the winding wheel next to the barrel. That wheel's inner radius is much too large and was no doubt part of the problem. I can fit the back plate on alright and everything seems correct but it won't run. I checked the barrel and when I use tweezers and move it there's plenty of tension.
I'm unsure what the problem is, besides it's a fake piece of crap... Yes I do almost regret the purchase but this is mainly why I bought it because I knew there would be a problem and I wanted to troubleshoot it. I know I should have just gotten a real one but I can't afford one and this was wonderfully cheap and worked for a few weeks. Plus it looks nice and I just like it. Thank you for any help it is appreciated. Should I just buy an 8200 movement and replace what I need in that using this? ab9bff9221c09b74848762cdf4158f17.jpgae7168a0eb11ab12f22f965ea93a99cf.jpg03061468f2f13d8af312e027ec125fbb.jpga9330e6538351642e78922c9b3ac990a.jpgec22a9ff195a11306c88825fcffaf76d.jpg
Sent from my Z956 using Tapatalk
It looks a like genuine 8200 to me. I have attached one of my pics taken when servicing one last year.  I personally prefer the Citizens to the Seiko's.
Looks okay to me also . Either you haven't put it together properly or you could have broken a pivot or two. It's a pretty easy movement to service . But many pivots need  to find the right place when put the trainwheel bridge on . There is a click spring that need to sit right also.
I would go and buy a new 8200 or i think a 8215 would work to instead.
Maybe it just needs an oiling? Yeah it is pretty simple idk what I'm doing, the picks seem fine, I'll include pics later, escape wheel doesn't seem to wanna align or move. But I didn't move it or do anything to it.
You were right, if you can see I think it's the fourth wheel top pivot is broken. I knew I had the train right. I'm also quite happy it's a genuine miyota movement. Thanks for the clarification... It's just a refurb'd dial. Thanks for the help.
Also, I know it's a topic of Pandora's box but oiling... I'm planning on getting Novostar B and Molykote DX as my starting oils as funds are limited. Do you have a suggestion for a third or fourth that I will most definitely need when servicing MY OWN, not anyone elses. Oh I'm getting a clock oil as well should that cover my bases? I'm feeling like I'm going to need a 9415 or equivalent as well. Any help is appreciated57de78b84c2921bed316cc7b2ae668d8.jpgb2accd57536e1a0fa31fffe9537d251d.jpgfba81830429e9396e29ceaaa32955c57.jpg
You ideally need three oils/greases as a minimum, but you could potentially get away with just two of you substitute the grease for a thicker oil. Further down the road you will buy more.
Grease for the mainspring (braking type of for autos). Can often be used on keyless and calendar works if non-braking.
Thick oil for slower part of the train (centre (2nd), 3rd wheel pivots), barrel arbor, canon pinion, keyless works, sometimes automatic works.
Fine oil for faster part of the train (4th, escape (5th)) balance pivots, and pallet faces.
For the fine oil where the train will be moving at a much faster rate with lower torque, there is an argument for getting something which will last a long time and maintain its performance. Some would suggest something fully synthetic like Moebius 9010.
It’s best if you research yourself and make your own decisions. Watchmakers can be very  stubborn and self-assured when it comes to discussing lubrication. Read about the difference between natural, mineral, and synthetic oils and how they vary in qualities. Some creep, some turn acidic, some dry out easily, some thicken, etc, etc. Just watch out for the snake oil!
    • I'd leave the Benrus till you've got more experience as information and parts are non existent and donor movements are expensive. I know it's based on something like an ETA 2370 but what they changed and what's still compatible is unknown.
    • Hello and welcome to the WRT forum.
    • No, a light. PS, it's a Unicorn   hehe.
    • As a fellow newbie who's made a bunch of mistakes over the past year or 2 I'd like to offer my experience. I didn't start with a new practice movement, I started with 1970s Tissot that I loved. If I could do it over I would still use a vintage watch for my first movement. I wouldn't, however, chose one I cared about or that was expensive. It also had a calendar complication- dont do that. I learned a lot about part compatibility and movement families right away though! Emmy watch and Ranfft are great resources for this! I would start with the Benrus and go ahead and find a parts movement right away YOU WILL BREAK AND LOSE PARTS! Get good tweezers, it's much harder to handle tiny springs than YouTube would suggest. And be extra carful, pivots don't like to be forced into jewels - bridges are a real pain in the ass at the start. Don't be afraid to use your bare hands to hold parts/bridges and handle the movement. Finger cotts can come later. Be as carful as possible with hairsprings, this can ruin all the fun!  Buy a cheap demagnitizer. For me, I think its fine to buy cheap tools in the beginning and replace as you go. But some things I wish I'd have spent more money on right of the bat - TWEEZERS and Rodico (don't get the fake stuff). There's a great thread here on Chinese tools. I used a cheap digital microscope for a long time. I got quite good at working under it even with no depth perception. It's probably better to just use loupes but I think it helped me be more mindful and it was great for inspection. I now have a stereo microscope and if you get really into this hobby, it's a must. I cleaned everything by hand in the beginning. This is great for getting familiar with each part and learning to inspect for faults. Peg your jewels! I still hand clean a lot of parts before the ultrasonic. I still use JUST Naptha and IPA and I think thats adequate for my hobby purposes but maybe I'll have moved up in another year. I swish the shellaced parts in IPA for a few seconds to rinse (don't tell anyone). I used to dry each part on a sheet of paper with a puffer. Again, this is good for getting to know each part. I now dry everything in a food dehydrator. Im not going to give any advice on oil because thats suicide. But... until very recently I used just mobius 8000 and Molycote DX for everything. I dont know if I would do it differently If I were to go back but its definitely cheap and it will teach you how to apply oil.  Take a picture after every move even if it's just scratching yourself.  Wind mainsprings by hand until you decide you like the hobby, spend that winder money on tweezers and parts movements. This place is great, there are a bunch of incredible KNOWLEDGEABLE guys willing to help you. Unfortunately, this is as much as I can help, as I'm nowhere near their level.  Oh... and buy a big magnet. Still one of my favorite watches and it reminds me of all the broken pivots and pinged springs every time I put it on.   worth every penny.
    • @RichardHarris123is that a pony chrono pusher?
