How would one polish/repair this ?
As the title says how would you remove this "stain" or mark on the metal ?
Does this look like chrome/nickel ? Could this be plated or is it solid metal ? This is a Longines pocket watch from the 1910s in case anyone wonders.
I'm guessing someone may have tried some acid or stone testing on it to see if it's silver ?
I have some of that diamond paste that's supposedly used for mirror finishing but not sure how to proceed here.
IMG_7281.jpgupload gambar
Edited by Chopin
Are there any markings on the inside of the case back if its European and silver from that era it will have some form of halllmark on it anyone testing for silver content and leaving a mark like that is an idiot imho.
I would guess at the case being one of the lower grade silvers 800 standard but this would be marked as such.
It's not silver. I gave it a go with one of the polishing pastes that I had and it worked perfectly. Now pondering whether to "shine" the entire case...
I'm guessing it's stainless steel ?
Its probably nickel plated. Stainless didnt become popular in watch manufacture until the  early 1930's it was too difficult to work using method in use at the time and far too expensive a material when first introduced in 1913.
I think the resistance to wear will have more to do with the hardness of nickle as opposed to the hardness of gold which is much softer, pocket watches on the whole fair better than wristwatches having spent most there life in a waist coat pocket.
But whatever the materials used if in regular use it will eventually wear but I have many plated pocket watches over 100 years old that are still in very good shape, but I avoid gold plated  or chrome plated wristwatches of any era because they dont hold up well to constant use once the edges of the plating on the case starts to go its all down hill from there.
    • 🤣 i think your first statement is rather dramatic, but i will take it in good humour.  I think the thread speaks for itself John.  What we are aiming for and when i say we, thats not actually that many that have spoke up. Is to have a back up plan to keep members in touch in case the forum ever disappears. So in essence yes the group has maybe taken on a life of its own and would like to remain together forever ( 🤣 i can also be dramatic )  maybe more members need to give some input of how they feel about it or say they are just not that bothered.  Either way at least the question gets answered. Can i ask what the forum means to you and how you would feel without it ?
    • you should go to the European patent office and look up watch patents. I'm guessing it's probably impossible to make anything related to watches without stepping on somebody's patent it's good that they expire with time. They've literally as far as I can tell patented everything and anything. this is why is pointing out their other formulas for the Epilam I'm pretty sure Rolex might have their own formula for instance. somewhere in the universe I was once reading things that were rejected for patents for basically this kind of thing. So yes there is rules on what can and cannot be patented but I'm sure things fall through the cracks.
    • Here is all the info on the 'Brocot' suspension block and regulating arbor. http://www.ian-partridge.co.uk/brocotsq.htm
    • I usually don't read new introductions but when you came to the group did you want to learn watch repair? The reason I ask is your watch seems so suffered some damage under your hands. And now you're ready to move on to a new patient and have you learned? I often relate watch repair like learning to be a doctor lots of practicing. Even though this is a damaged watch have you practice taking it apart and putting it together a whole bunch at times so you feel confident that the next watch you probably won't break anything? Then when watches were invented specifically pallet forks they didn't have epoxy glue which even if they did they wouldn't you used anyway because the pallet stones need to be moved around they need to be adjusted. so the substance of choice for holding pallet stones and roller jewel's in is shellac. It's a really interesting substance were if it's warmed up at melts the palace on can be moved around hopefully the correct position when it cools shellac hardens back up in the pallet stone will be held in place. If you're carefully could probably put your pallet stone back just warm up the fork carefully ideally there's a tool for this and your pallet stone would be fine.
    • Hi @JohnR725, I would say its a happy end, the watch was in a much worser state and turned out quite nice(imho). I just hoped for a higher result after all that work.  I agree with you, as long as it runs and keeps time, Im happy. Thank you for your advices!
